Author Topic: AGU timing belt loose?  (Read 3255 times)
Offline spaced4130
  • 99 AGU 1.8t
« on: 13 March 2012, 13:55 »
Hi All,
I got my timing belt and water pump changed in December last year but stupidly didn't get the hydraulic tensioner/dampener replaced at the same time! The last couple of days I've noticed a rattling noise coming from the engine bay at low revs, it doesn't happen all the time but does happen when stationary as well, At first I thought I was a lose heat shield or something but I cant see anything lose. After a search I found a couple of posts on other forums about the dampener being the problem so took the timing belt cover off to have a look and it seems a bit loose, I took a video of how loose it was, do you guys think this is normal:-
http://www.youtube.com/watch?v=uEr8t6vqOgk&feature=youtu.be
It wasn't making the rattling noise when I started the car up with the timing belt cover off either so I'm not really sure what's going on or if the belt should be that loose.
Thanks in advance for your help
Offline Big Tone
Re: AGU timing belt loose?
« Reply #1 on: 13 March 2012, 14:13 »
Can you twist the belt through 90degrees with sensible finger pressure? Or more than 90degrees?
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline spaced4130
  • 99 AGU 1.8t
« Reply #2 on: 13 March 2012, 14:16 »
I think I probably could to be honest but not entirely sure so I will have a look a bit later and get back to you.
Offline Big Tone
« Reply #3 on: 13 March 2012, 14:22 »
Just watched the vid, slack as fook!
How long you driven like that?
Offline spaced4130
  • 99 AGU 1.8t
« Reply #4 on: 13 March 2012, 14:31 »
I'm not sure how long its been like that, as I say I got the belt and water pump done in December. Its only started making the rattling noise in the last few days so I assume that's the tensioner bouncing on the pulley then?
Do you think I shouldn't drive it until I've got it sorted? I fell like a complete twit for not getting the tensioner done at the same time now  :cry:
Offline Big Tone
« Reply #5 on: 13 March 2012, 14:36 »
I wouldn't be driving it, id be hoping I aint broke owt!
Offline spaced4130
  • 99 AGU 1.8t
« Reply #6 on: 13 March 2012, 14:41 »
looks like I'll be getting the train home then
Offline Big Tone
« Reply #7 on: 13 March 2012, 14:44 »
Someone please confirm, our take a longer better video to be sure. Dont want to give you duff advice.
Could the belt jump a tooth? Can you reach the idler pulley? You should be able to tell if its loose.
« Last Edit: 13 March 2012, 14:56 by Big Tone »
Offline GunnerCP
« Reply #8 on: 13 March 2012, 14:45 »
i'm no expert either but looks far from normal/safe and I wouldnt advise driving it either!
Offline Dave_IOW
« Reply #9 on: 13 March 2012, 17:57 »
I dont think its that bad???
Do bloody well to skip a tooth id have thought??  :huh:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
