Author Topic: AGU timing belt loose?  (Read 3257 times)
Offline spaced4130
  • 99 AGU 1.8t
Re: AGU timing belt loose?
« Reply #10 on: 13 March 2012, 20:01 »
I had another look at it, it seems a lot tighter than the last time I looked at it, maybe all the slack was on just one side or something. I felt the pulley and it doesn't feel loose, I have also worked out that the rattling was the heat shield under the car after having a bit more of a poke around so my mistake. Do you reckon the belt is alright then Dave??
Offline Big Tone
« Reply #11 on: 13 March 2012, 20:12 »
There is a slack side but if the pulley is tight, you can't twist the belt through more than 90deg, and the rattling was definatley the heat shield, id say the belt is ok, you would know about it if it wasn't.
Still say that it Looks a bit slack on that vid, just the way the lower part of the belt moves but you can't tell how much force you are applying.
Glad its not the belt snd sorry for freaking you out, my bad.
I would certainty be replacing that tensioner though.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline Dave_IOW
« Reply #12 on: 13 March 2012, 20:39 »
One way to find out!
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Big Tone
« Reply #13 on: 13 March 2012, 20:47 »
Lol, if its the rattling he ws concerned about snd he has found it, then hopefully everything is fine.
