Author Topic: OIL????  (Read 2785 times)
Offline ben gttdi
OIL????
« on: 12 March 2012, 17:04 »
i oil changed my car the other day, since then iv checked the level n it was over full, if you run the car for a little as a min it read underfilled  :shocked: so which is the correct reading? cause if i leave the car to stand over an hour its overfull?
Offline Toby
  • Car - less
Re: OIL????
« Reply #1 on: 12 March 2012, 17:10 »
is the dipstick holder, and dipstick in correctly  :lipsrsealed:
Currently down under
Offline ben gttdi
Re: OIL????
« Reply #2 on: 12 March 2012, 17:12 »
of course lol
Offline The Mighty Elvi
  • I'm better than you today.
Re: OIL????
« Reply #3 on: 12 March 2012, 17:18 »
The oil level reading is taken from the sump volume.  When you start the engine, the oil is pumped from the sump around the engine.  Hence the lower oil reading, as the sump volume is reduced.
Oil level volume from cold is what you are after.
Offline ben gttdi
Re: OIL????
« Reply #4 on: 12 March 2012, 17:20 »
its been sitting there about an hour n alf now so if i dip it now thats the true reading?
Re: OIL????
« Reply #5 on: 12 March 2012, 17:22 »
Should be. Are you parked on level ground?
Offline ben gttdi
Re: OIL????
« Reply #6 on: 12 March 2012, 17:27 »
yep n my cars standard ride height
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: OIL????
« Reply #7 on: 12 March 2012, 17:31 »
Id expect this sort of question from a girl
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Sam
  • Sam I am
Re: OIL????
« Reply #8 on: 12 March 2012, 17:52 »
Was it chuff that had to stop that woman brimming her car with oil cos she thought you had to be able to fill it up to the oil fill hole?  :laugh:
Offline F17BAD
Re: OIL????
« Reply #9 on: 12 March 2012, 17:56 »
hahahahahahaha really ? :grin: :grin: :grin: :grin:
