Author Topic: shocking discovery  (Read 2467 times)
Offline 16valver dan
  • 1.8 20v turbo MK4 Golf
shocking discovery
« on: 12 March 2012, 14:43 »
guys i need help bollax to the idle problems the car lumped full turn today had a look and the suspension mount under the bonnet is looking dangerous the top mount is 2 inches from the chassis but when you jack the car up it goes flush is this just been badly fitted or is the car screwed
il update the sig when i get a good photoshoot ;)
Offline kennedyuk2001
Re: shocking discovery
« Reply #1 on: 12 March 2012, 14:46 »
The mounts do sit flush when jacked up, and will rise when sitting on ground, perfectly normal.
« Reply #2 on: 12 March 2012, 14:49 »
but the diferent on each side plus the passenger side one looks like it diagonal
« Reply #3 on: 12 March 2012, 14:57 »
Thats how mine sit.
« Reply #4 on: 12 March 2012, 14:58 »
ok looks like mine worries are over im guessing the knocking at full lock is them on the way out
« Reply #5 on: 12 March 2012, 15:00 »
Knocking on full lock could be the cv joint.
« Last Edit: 12 March 2012, 15:05 by kennedyuk2001 »
« Reply #6 on: 12 March 2012, 15:04 »
il look into it cheers :)
« Reply #7 on: 12 March 2012, 16:35 »
« Reply #8 on: 12 March 2012, 16:43 »
What needs replacing exactly. Been to the garage with them like that for ages and never had anything mentioned about them, not long had the strut bearing replaced on the drivers side and it was looked at that side and no concerns were made.
« Reply #9 on: 12 March 2012, 17:07 »
It needs the top mount replacing, how a garage can say that is fine is beyond me, they should be replaced in pairs as well.
