Golf mk2
Sunroof problem
Topic: Sunroof problem (Read 2739 times)
9thwonder
Sunroof problem
10 March 2012, 22:01 »
Right just picked up my car and I went to wind the sunroof back and only one side starts to go and it just starts to slide back at an angle until it won't go anymore because it wedges?? Im stuck for ideas and I'm not sure how to even get at the sunroof?
My car is an 89 gti 16v if that makes a difference?
Thanks anyone who can help.
Thom89
Forum addict
Looking for an "Icebreaker"
Re: Sunroof problem
10 March 2012, 23:23 »
You need these
http://www.ebay.co.uk/itm/VW-GOLF-MK1-MK2-SCIROCCO-SUNROOF-MECHANISM-CABLE-/260973834635?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cc340b18b#ht_607wt_946
But in all honesty, I'd try and locate some brand new ones, for the simple reason that old ones break!
Thom
9thwonder
Re: Sunroof problem
12 March 2012, 13:10 »
do you know how to get at the mechanics of the sunroof to check it out or to replace it?
Thanks
Thom89
Forum addict
Re: Sunroof problem
12 March 2012, 13:34 »
It's a very involved job, that pretty much needs the whole sunroof stripping down, I had a look for an online "how to" guide, but drew a blank...
Anyone?
Thom
Steve_B
Re: Sunroof problem
12 March 2012, 19:01 »
This will be a start, shows you how to remove the sunroof:
http://www.golfgtiforum.co.uk/index.php?topic=33684.0
Check the parts that hold up the rear of the sunroof, if your problem is the same as mine was the black runner in picture 4 has broken. You'll need to unscrew the frame holding the cables and either replace the whole thing or the faulty cable, depending on what you get hold of.
Need to redo this myself as my replacement parts have now also broken. Might be able to help you out with parts. Will be taking 2 sets of cables and combining to make one good one so might have some useable stuff left after that.
daveybwoy
Re: Sunroof problem
12 March 2012, 19:06 »
I've renewed the cables in the past. I got my cables from the USA and they worked out slightly cheaper then here but still expensive.
Here is the company I got them from and had no problems. Didn't take that long to get here either.
http://www.ebay.co.uk/itm/Gen-Vw-Mk1-Mk2-Rabbit-Golf-Jetta-Sunroof-Cable-Kit-NEW-/220364864438?pt=Motors_Car_Truck_Parts_Accessories&hash=item334ec4fbb6
For reference its section 11.14 of the Haynes manual which is linked here
http://www.golfgtiforum.co.uk/index.php?topic=189837.0
Last Edit: 12 March 2012, 19:08 by daveybwoy
9thwonder
Re: Sunroof problem
Reply #6 on:
13 March 2012, 01:03 »
Thanks for your replies I'll have a look at the weekend and see what's wrong with it.
Golf mk2
Sunroof problem
