Author Topic: Golf GTI 1.8t questions  (Read 8490 times)
Offline mike1990
« on: 08 March 2012, 19:50 »
Hello everyone i'm new here, i've just bought a 51 plate golf gti 1.8t aum engine
Few problems with it, nothing major.. when starting the car the half height display reads "AIRBAG FAULT" then beeps, then that goes off and it says "SERVICE NOW" i understand the service now, but it's only just been serviced. I don't know what the airbag problem is though.
There is a crack in the passenger side wing mirror, could the mirror just be replaced?
Also, the boot won't open.. i've tried turning the key in the boot and the barrel wont move. The handle doesn't do anything either.
Could anyone shed any light to my problems?
Offline richw911
Re: Golf GTI 1.8t questions
« Reply #1 on: 08 March 2012, 20:15 »
Welcome  :cool:
See this for the service indicator.
http://www.golfgtiforum.co.uk/index.php?topic=62717.0
Air bag fault could be the plugs under the seats.
The mirror can be replaced which part is broken glass of the cover? You can get bits here http://www.vwspares.co.uk/g4body.php
The lock in the barrel is seized common fault try some WD40  :smiley:
Offline mike1990
« Reply #2 on: 08 March 2012, 20:20 »
Thank you :) it's the mirror, not the case. I'll try the WD40 tomorrow.
Offline mike1990
« Reply #3 on: 08 March 2012, 21:12 »
Also, the ASR button doesn't seem to work, i press it and nothing happens.. the traction control light doesn't come up on system check when i turn the key. I think it could possibly be the fuse but i don't know really.
Any advice or information would be appreciated
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #4 on: 08 March 2012, 21:20 »
You got a fault scanner? Or a version of VAGCOM available to hand? If so run a scan on it and it should give you anything and everything that is wrong...or try and borrow one, there is a 'lend a hand section' and a vagcom map, try contacting a few members perhaps! :smiley:
Offline mike1990
« Reply #5 on: 08 March 2012, 21:26 »
I do yes, although i've got the old usb 16pin obdii lead that i bought for my old polo 16v, i'm not sure if that would still work
« Reply #6 on: 08 March 2012, 21:53 »
The ASR might not be working due to the ABS fault, get it scanned for codes as a 1st step.
Offline mike1990
« Reply #7 on: 11 March 2012, 13:17 »
I've now scanned the car for fault codes and i'll copy and paste the log
Quote
VAG-COM Version: Release 409.1-S
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,16,15,17,19,22,35,46,56
Address 01: Engine
   Controller: 06A 906 032 HJ
   Component: 1.8L R4/5VT         0002
   Coding: 11500
   Shop #: WSC 00028
   WVWZZZ1JZ2P049312     VWZ7Z0A4279546
2 Faults Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
            P0102 - 35-00 - -
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
            P1650 - 35-10 - - - Intermittent
Readiness: 0000 1101
Address 03: ABS Brakes
   Controller: 1C0 907 379 K
   Component: ASR FRONT MK60      0103
   Coding: 0021505
   Shop #: WSC 00028
1 Fault Found:
01314 - Engine Control Module
            013 - Check DTC Memory
Address 08: Auto HVAC
   Controller: 3B2 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 00028
No fault code found.
Skipping Address 15-Airbags
Address 17: Instruments
   Controller: 1J0 920 926 A
   Component: KOMBI+WEGFAHRSP VDO V06
   Coding: 05412
   Shop #: WSC 00000
7 Faults Found:
00779 - Outside Air Temp Sensor (G17)
            30-10 - Open or Short to B+ - Intermittent
01128 - Immobilizer Pickup Coil (D2)
01176 - Key
            07-10 - Signal too Low - Intermittent
            49-10 - No Communications - Intermittent
01316 - ABS Control Module
01321 - Control Module for Airbags (J234)
01336 - Data Bus for Comfort System
Address 19: CAN Gateway
   Controller: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 00028
4 Faults Found:
Address 46: Central Conv.
   Controller: 1C0 959 799 B
   Component: 1X Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00028
1 Fault Found:
00930 - Locking Module for Central Locking: Rear Left (F222)
            27-10 - Implausible Signal - Intermittent
Address 56: Radio
   Controller: 1J0 035 186 D
   Component:  RADIO SON         0004
   Coding: 01403
   Shop #: WSC 00028
End   --------------------------------------------------------------------------------------------------
Offline rio_gti
« Reply #8 on: 11 March 2012, 14:15 »
Clear all the codes and see what appears after that some can be old
Offline mike1990
« Reply #9 on: 11 March 2012, 15:52 »
I erased them, started the car and then scanned again here is the log
Quote
Address 01: Engine
   Coding: 11500
   Shop #: WSC 00028
1 Fault Found:
            P0102 - 35-00 - -
Readiness: 0110 1101
   Coding: 0021505
   Shop #: WSC 00028
1 Fault Found:
   Coding: 11000
   Shop #: WSC 00028
   Coding: 05412
   Shop #: WSC 00000
   Coding: 00006
   Shop #: WSC 00028
   Coding: 00258
   Shop #: WSC 00028
Address 56: Radio
   Coding: 01403
   Shop #: WSC 00028
