Golf mk4
Wazzzer
Golf GTI 1.8t questions
Topic: Golf GTI 1.8t questions (Read 8502 times)
rio_gti
"i'm not spending any money on it" Got a Hybrid!
Re: Golf GTI 1.8t questions
Reply #10 on:
11 March 2012, 19:09 »
16486/P0102/000258 - Mass Air Flow Sensor (MAF/G70): Signal too Low
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Loss of Power
Possible Causes
Wiring and/or Connector(s) from/to Mass Air Flow Sensor (MAF/G70) faulty
Possible Solutions
Check Wiring and/or Connector(s) from/to Mass Air Flow Sensor (MAF/G70)
Check/Replace Mass Air Flow Sensor (MAF/G70)
01314 - Engine Control Module: Check DTC Memory
Possible Causes
Fault(s) stored in Engine Control Module
Possible Solutions
Check Engine Control Module for Fault Codes
Special Notes
Engine Control Module stored a Code which influences other Control Modules Functionality.
To clear this Fault Code you will need to correct the Problem in the Engine Control Module first.
2000 GTI 1.8t ARZ, S2000 filter, DSG intake, Forge 007 dv, Catch can, R-tech custom remap, 3" Supersize Silicone TIP, Powerflex dog bone, 'The Beast' FMIC, Ultimate delete, LCR fuel pump, 3" Turbo back, K03 hybrid, Ported Manifold, S3 injectors, 80mm maf = 280bhp 270lbft
mike1990
GTI forum regular
Reply #11 on:
11 March 2012, 19:21 »
Thank you, how would i check the ECM in vagcom 409.1? i just cleared all error codes and rescanned.
Also, i found this hose had split.. not sure if it's anything to do with the MAF
The ABS light doesn't light up on engine startup
navmk4gti
Forum addict
Reply #12 on:
11 March 2012, 19:50 »
i had exact same hose split too and it fooked my maf.. get silicone replacement off the bay mate
Website:
https://www.theonestopledshop.com/
mike1990
GTI forum regular
Reply #13 on:
11 March 2012, 22:54 »
I will do mate, what are they called?
Also, how do i get to the engine control module in vagcom?
Is it the 01 - Engine controller? just i thought doing vagcoms Auto Scan would of picked up the codes for the ABS problem
Golf mk4
Wazzzer
