Author Topic: I doing some pointing on the roof and the chimney looks FOKED!  (Read 8364 times)
Offline clipperjay
Any suggestions would be good  :laugh: :lipsrsealed:
I have the following materials & tools: :grin:
Larfarge yellow cement bag 10KG
20KG building sand
A 100ltr plastic bucket
one spade
one angle grinder with dimond cutter blade
Oh yeah scafolding aswell doing it right LOL!
I have no building experience so break me gentley!
Offline Diamond Hell
  • Opinions я Us
Do you have a mobile phone and access to Google?
I think these would be the most valuable assets at this difficult (and shortly to be more expensive) time.
Offline clipperjay
You should come over and help me DH I heard you're good with a hammer  :smug:
Offline Kerrse
Thats needs to be removed & rebuilt before it comes down  :shocked: all depends how good your bricklaying skills are?
Offline luke
  • When in doubt, whip it out!
if that was me i'd need some bigger testicles  :grin:
1985 mk2 gti type 19 8v
2018 t roc sel 1.6tdi
Offline bomp
The tapered chimney looks like only two bricks need replacing, but the smaller one needs taking down to the lead flash and rebuilding, because another cold winter will only split the bricks even worse.
Notice how the pointing on the tapered one has probably preserved the bricks through the weather/time.
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline clipperjay
Well I'm doing the easy bit chimney one and coping stones the second FOked one I've never seen and three corses need removing and rebuilding.
The only issue I have is I'll need scafolding across neighbours drive and his flat roof just to get to it otherwise if I don't get permission I'll have to get water ballast to counter any funny scafolding drapped over the roof!
Anyone use easy rake looks like a routing tool but not sure if worth it? £50 odd quid the diamond disc alredy cost me £20.00! Plus spent £40 on the angle grinder my old one had just died from abuse!
The money could have gone on my MK2  :sad:
Offline The Mighty Elvi
  • I'm better than you today.
Agreed.
I took down and rebuilt a 5 ft brick pillar last summer. It's easy once you get the hand of it.
Offline justalex81
you'll need a 2ft spirit level  :wink:
Offline clipperjay
Dont laugh Alex this little discovery has set me back a few quid that could have gone on the new boiler system  :lipsrsealed:
Agreed.
Its all about time to me Jon I've not used cement and bricks before  :embarassed: if it was on ground level I would have a go, but the cost of scafolding these days its not cheap rather have someone just take out the bad courses and cap it over.
The fire place is not being used plus if I wanted full tile replacement it would mean more money and noone can see that side of the house.
Anyone near who can do such a job? the scafolding will be inplace before anyone comes I need to plan it now or come winter I fear the worst TBH. :rolleyes:
