Author Topic: Quick vagcom q  (Read 937 times)
Offline boyob32
  • 1.8T
Quick vagcom q
« on: 07 March 2012, 17:03 »
Using my laptop is no issue so,  am I better off buying a fault reader/clearer or a cable with basic software?
Offline GunnerCP
Re: Quick vagcom q
« Reply #1 on: 07 March 2012, 17:10 »
a cable with cracked software.....!
Offline Mr_Orange
Re: Quick vagcom q
« Reply #2 on: 07 March 2012, 17:11 »
If you have a laptop an OBD2 cable and vagcom software is cheaper than a code reader and can do more cool stuff.
A code reader will always be in the car when you need it.
Up to you matey
Build thread clicky
Offline barrym381
Re: Quick vagcom q
« Reply #3 on: 07 March 2012, 17:11 »
the cheap handheld 1s work oh an mine lives in my glovebox incase i need it while away from home  :smiley:
Offline boyob32
  • 1.8T
Re: Quick vagcom q
« Reply #4 on: 07 March 2012, 17:15 »
Hmmm may plump for the cable... Then I could be all fancy with autolocking and other stuff I'm yet to know about!
Offline barrym381
Re: Quick vagcom q
« Reply #5 on: 07 March 2012, 17:21 »
or find some1 local to you an give them some beer tokens to do it for you :grin:
Offline Scott D
Re: Quick vagcom q
« Reply #6 on: 08 March 2012, 00:10 »
always handy to have a code reader in the car for the sake of 20 quid.
worth getting vagcom tho for functions and logging.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
