Author Topic: Rumbling from the rear!  (Read 4031 times)
Offline Snoopy
  • Moderator
  • Geoff.
« on: 06 March 2012, 20:35 »
Mk5 owners post http://www.golfgtiforum.co.uk/index.php?topic=223810.0
Any mark 6 owners here suffered from it.  :lipsrsealed:
Current Garage:
35+ years of GTI ownership.
Jimmymature
Re: Rumbling from the rear!
« Reply #1 on: 06 March 2012, 20:39 »
I have a noise that sounds like wheel bearings but its the uneven wear from my Dunlops.
Jim
Offline mike.
« Reply #2 on: 06 March 2012, 20:44 »
Yea it seems to be common with all front wheel drive cars with the modern tyre design.
Called Heel Toe wear and looks like this
Heel and Toe wear occurs when the tread-block passes through the contact area. The leading edge of the block is compressed at the moment of contact - which slows down the rate rotation on that particular tread block. The trailing edge of the block has to accelerate to catch up with the general rotation of the tyre and "flicks" through the point of contact causing more wear at that point.
I have just fitted a set on Continental Contactsport 5 and notice they have a joint between the blocks on the inside of the tyre which may prevent this.
« Last Edit: 06 March 2012, 20:47 by mike. »
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Edi35
« Reply #3 on: 06 March 2012, 20:45 »
I have heard of this problem but luckily havent suffered this so far, had Dunlops on my MK6 too.
Current: GTI Edition 35 Candy White 5dr DSG 19" Glendale, RCD510+DAB, Dynaudio, Storage Pack, Parking Sensors
Gone: Edition 35, GTI Mk6, Edition 30, GTI Mk4, GTI Mk3, GTI Mk2 and my favourite the UR quattro
For those that dont know DSG is an electronically controlled dual-clutch multiple-shaft manual gearbox
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #4 on: 06 March 2012, 20:47 »
If i find this is what it is i wonder if i put the front tyres on the back and the backs on the front  :undecided:
Current Garage:
Offline mike.
« Reply #5 on: 06 March 2012, 20:54 »
Switching the tyres from left to right should even up the tyre wear as long as they are not directional.
Offline SRGTD
« Reply #6 on: 06 March 2012, 21:51 »
Had this on my mk5 GT TDI PD 170 with Bridgestones on the standard 17" wheels. The rumbling became noticeable at around 16k miles and got progressively louder over time. The 'sawtooth' wear pattern on the inside edge of the tyre tread could be felt and was easily visible.
I'm keeping a watch on my mk6, which unfortunately also came with Bridgestones.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline ajmoir36
« Reply #7 on: 06 March 2012, 22:30 »
Yeah my GTD does it on the Bridgestones, I swear the PS3s are doing it too. 18" Vancouvers.  Just turn the radio up louder.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline mac7
« Reply #8 on: 07 March 2012, 18:53 »
The Dunlops on my R don't seem to be suffering in this way, but that might be because I run high tyre pressures. However I'm interested in identifying the cause of this problem and don't believe it has been properly explained anywhere. The Heel/toe wear of individual tread blocks mentioned by mike is a factor of the toe-in and camber of the tyre but I can't see how it would make the tyre go 50p-shaped.
Has anyone ever counted the number of flat spots which form on the affected tyres?
Golf R
Offline dubber36
« Reply #9 on: 08 March 2012, 17:42 »
My GT is very noisy. I put it down the the cheepo ditchfinders that the dealer had fitted on the front before I bought I. I soon changed them for a pair of Dunlops to match the rear, and while the noise was lessend, it was still there.
I'm driving a 1.4S courtesy car at the moment, with 205-55-16 Hankooks. This is a little quieter that the 18" Dunlops on the GT, but there is still that wheel bearing rumble noise coming from the rear.
