Author Topic: oil light on after catch can install (UPDATE NOW FIXED)  (Read 2638 times)
Offline rio_gti
Re: oil light on after catch can install
« Reply #10 on: 06 March 2012, 20:22 »
Remove and re connect the oil sensor plug?? I dunno that's the best I can think of!!!!
Offline cullygti
« Reply #11 on: 06 March 2012, 21:29 »
where is the oil sensor plug as there seems to be loads of sensors round that area  :undecided:  :smiley:
Offline rio_gti
« Reply #12 on: 06 March 2012, 21:44 »
Bottom of the sump!!!
Offline cullygti
« Reply #13 on: 06 March 2012, 21:45 »
chers rio will have a look in the morning  :wink:
Offline james2
  • No scammers please.
« Reply #14 on: 06 March 2012, 23:52 »
remove the catch can, put back to standard . sorted . :wink: you must of fitted it wrong .  :nerd: If it was fine before fitting something thats your problem.  :laugh:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
« Reply #15 on: 07 March 2012, 00:03 »
That is the level sensor, oil pressure sender is on the filter housing, check around the filter housing and see if you have knocked a plug off.
Offline cullygti
« Reply #16 on: 07 March 2012, 00:06 »
cheers wayne gonna have a look tomorrow  :wink:
Offline cullygti
« Reply #17 on: 07 March 2012, 00:09 »
was thinking of it but hacked the old system up as it was falling apart with corrosion thats why catch can was installed  :grin:
« Reply #18 on: 07 March 2012, 00:09 »
What colour is the light yellow or red. :undecided:
Offline Big Tone
« Reply #19 on: 07 March 2012, 07:35 »
+1, or damaged the wiring, failing that there must be something wrong with the install, or a massive co-incidence.
In my experience, it will be something daft  :grin:
Do you have VAG-COM?
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
