Author Topic: k03s turbo problem  (Read 945 times)
Offline Jayz
k03s turbo problem
« on: 04 March 2012, 20:13 »
I've had my car custom mapped on my agu for a few weeks now and i love it. Recently when my turbo (k03s) kicks in I hear a whining noise which sounds like its supercharged but when im stuck in traffic and driving along at 5-10mph i can hear a rattling metal noise but when i driving over that and i come on boost it goes, i still boost up to 20-22psi and hold boost fine, no oil leaks etc
Is my turbo on its way out?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: k03s turbo problem
« Reply #1 on: 04 March 2012, 20:34 »
bearings are shot mate  :cry:
Offline Jayz
« Reply #2 on: 04 March 2012, 21:07 »
Bearings where? and can they be replaced or is it a new turbo?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 04 March 2012, 21:12 »
turbo shafts run on brass bearings (unless it's a ball bearing turbo) which in turn sit in the housings. If they are too far gone they can wear the core metal resulting in a lump of scrap :sad:
Bet bet is get the turbo off and get it looked at mate, it will probably have a fair bit of play in the shaft. Look for scores on the inlet housing where the blades may have been touching too
Offline Jayz
« Reply #4 on: 04 March 2012, 21:19 »
Damn! better not drive the car then!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 04 March 2012, 21:23 »
that's the problem, the turbo is ALWAYS spinning even if driving off boost  :sad:
You can have a quick check before you take the turbo off by taking the TIP off and giving the shaft a wiggle and a spin by hand. Any movement in/out isn't good and also any blades catching on the housing
Offline Jayz
« Reply #6 on: 04 March 2012, 21:33 »
Cheers Wazzer
