Golf mk4
Wazzzer
rough running and hesitation on cold
Topic: rough running and hesitation on cold (Read 714 times)
mk3tony
GTI forum regular
03 March 2012, 15:54 »
Hi every cold morning I start the car, it idles just over 1k, little rough and when moving off its a little hesitant. Throttle body cleaned not long ago and its brand new maf from vw. What else could it be? With maf unplugged it runs no issues
2001 1.8T AUM - Rtech Spec 1 Custom Map, Catch Can, Cone Filter, 209bhp 237 lb/ft, SuperPro Wishbone and Rear Beam Bushes, Jom Coilovers, 19" BBS CH Reps
mk3tony
GTI forum regular
Re: rough running and hesitation on cold
03 March 2012, 21:52 »
Anyone?
barrym381
Forum addict
03 March 2012, 21:57 »
Quote from: mk3tony on 03 March 2012, 21:52
Anyone?
does it run ok with maf unplugged
salgar3176
03 March 2012, 22:00 »
I had this issue and i changed 2 things Coolant sens. and throttle body.
when i 1st changed the temp sens. the car ran great but ticked over high over 1.2k
changed the TB all back to normal.
1st Have you checked for fault codes ?
but i i would say change TS 1st go for an OEM one not a cheap one then see how it runs.
Maybe someone else might also have some ideas.
good luck
mk3tony
GTI forum regular
03 March 2012, 23:01 »
runs fine with maf unplugged. also coolant temp sensor is new, scanned and no codes at all
Golf mk4
Wazzzer
