Author Topic: mk2 8v fuel issue?  (Read 4162 times)
Offline ians
mk2 8v fuel issue?
« on: 03 March 2012, 14:17 »
ok so its a 1990 golf gti 8v digi. was running well then stopped running after what sounded like misfiring under load, I'm getting spark, air and fuel to the injector rail, but should the plugs be getting wet if I'm pumping the accelerator peddle? because mine is not so I'm thinking that the injectors are not working? anyway to check at all? it cranks over but does not even try to fire up both the fuel pumps are priming and like i said i have fuel to the injector rail. I've also looked at the timing and its spot on.
Any help as I really need the car for work  :sad:
Offline AlexMozza
Re: mk2 8v fuel issue?
« Reply #1 on: 03 March 2012, 21:50 »
One way to check if the injectors are working is to take them out still attached to the rail. Crank the engine and it should spray fuel out of the injectors.
Just dont stand to close as it is highly atomised and the fuel can cut you very badly :o
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
« Reply #2 on: 03 March 2012, 23:49 »
I would not recommend that  :shocked: that could end in tears.
Offline ians
« Reply #3 on: 04 March 2012, 07:08 »
i've heard of people checking this way...didnt know it could cut tho  :shocked:
« Reply #4 on: 04 March 2012, 09:53 »
The bigger worry is petrol being sprayed everywhere, one spark and boom
Offline clipperjay
« Reply #5 on: 04 March 2012, 14:29 »
In the good old days we took one out then stuck them in big jam jars to collect any spray its to check pattern rather than leave it pissing fuel everywhere!
You can wrap a cloth at the top of the jar or cut recess into the lids, its visual notes more than anything.
Offline ians
« Reply #6 on: 04 March 2012, 14:58 »
that sounds like a good idea, I went out to check but cant figure out how to get the electrical clip iff the rail? I didnt want to force it I tried squeezing it and tried to prize out the retaining thing too...any ideas?
Offline clipperjay
« Reply #7 on: 04 March 2012, 15:02 »
It should come out check there is no hex bolts on the main body of the whole unit you might just need to give it a good pull of the retaining clips failing that try taking the clips off aswell?
TBH I can't remember all I do remember it came out okay?
Is it metal or plastic?
Offline AlexMozza
« Reply #8 on: 04 March 2012, 23:31 »
How about a Picoscope?
Could it detect the injector pulses?
2001 Satria GTi
Formula 3 Mechanic
Offline AlexMozza
« Reply #9 on: 04 March 2012, 23:33 »
Diesel is worse, at around 1500Psi, It can cut through bone, fingers, directly into the blood....
2001 Satria GTi
Formula 3 Mechanic
