Author Topic: mk2 8v fuel issue?  (Read 4122 times)
Offline ians
Re: mk2 8v fuel issue?
« Reply #10 on: 05 March 2012, 09:09 »
i've heard of people checking this way...didnt know it could cut tho  :shocked:
Diesel is worse, at around 1500Psi, It can cut through bone, fingers, directly into the blood....
ouch that made me cringe  :sad: where would I get one of the scope things to detect the pulse?  :smiley:
Offline AlexMozza
« Reply #11 on: 05 March 2012, 13:07 »
http://www.picotech.com/picoscope-oscilloscope-software.html
They are very expensive, but i think you can rent them?
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline ians
« Reply #12 on: 05 March 2012, 14:55 »
hmm I'm going to take them out as a complete unit and test in bottles as suggested. is it possible to clean the injectors at all?
thanks for your help so far  :wink:
Offline AlexMozza
« Reply #13 on: 05 March 2012, 15:39 »
Yes, you can get a fuel additive that does it. Otherwise for a real clean you need to send them off  to a specialist. However you might find that getting them cleaned etc could be nearly as much a new set :/
2001 Satria GTi
Formula 3 Mechanic
Offline ians
« Reply #14 on: 05 March 2012, 15:49 »
oh right thanks for that, were i get a set I've had a look around but cant find any i'm probably being dim tho, did a night shift last night :sick:
Offline ians
« Reply #15 on: 05 March 2012, 15:52 »
found these but mines a 1990
http://www.gti-bits.co.uk/carbsinjectors.htm
heritage do em but only says kjet?
Offline clipperjay
« Reply #16 on: 05 March 2012, 16:02 »
You can take the injectors off and send them for servicing mate as for diesels atomising the fuel you own a 8V petrol  :wink:
