Author Topic: Shocks  (Read 2886 times)
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Shocks
« on: 26 February 2012, 11:26 »
I have a suspension kit for sale (original oem) and noticed the other day that when you push down on the shocks, the pole doesn't return to its original position. Just goes to wherever you push or pull it to..
Is this normal?
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Shocks
« Reply #1 on: 26 February 2012, 11:31 »
I think the spring does that for you. The shocks are there to dampen the affect of a bump or lump and the spring returns it back to the original position. I THINK.... :smiley:
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Re: Shocks
« Reply #2 on: 26 February 2012, 11:45 »
Ok thanks for the reply. Just need some input as I don't wanna sell them if they are faulty.
Hopefully you are right.
Offline scarr89
Re: Shocks
« Reply #3 on: 26 February 2012, 19:21 »
I think it is. As on coilies if you wind them down, ie compressing the springs, you get a stiffer ride. Wait for someone to confrim though  :laugh:
Offline kahunajb
Re: Shocks
« Reply #4 on: 26 February 2012, 20:41 »
I've got a set of second hand Koni shocks waiting to go on and when the shock is compressed it slowly returns to position. They are adjustable which alters the force required to compress them and the speed at which they return. Would be interested to know if this was as it should be.
Mk1 Leon Cupra TDI - Keeping
Mk5 Golf GTI - Revo Stage 1 - FOR SALE £5,250
Mk3 GTI 16v Anniversary - OEM+ - Gone :(
Mk4 GTI 2.0 - Slow - Good Riddance
Offline Deano2711
  • 1992 VR6
Re: Shocks
« Reply #5 on: 26 February 2012, 20:46 »
As said they normally stay where you push then as the spring does the work when fitted to the car  :cool:
Offline scarr89
Re: Shocks
« Reply #6 on: 26 February 2012, 20:48 »
I did say I wasn't sure  :lipsrsealed:
Offline kahunajb
Re: Shocks
« Reply #7 on: 26 February 2012, 21:06 »
Does that mean there is something wrong with mine then? Strange if there is as all four are like that.
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Re: Shocks
« Reply #8 on: 26 February 2012, 21:10 »
Just had another look at them, and they SLOWLY return back to their original position of fully out.
Was just looking at videos on youtube and the ones on there were a lot quicker at returning back to their original position but maybe that is because they were a different setup or for a different car  :undecided:
Oh well, at least they move slowly. Better than not at all  :laugh:
Offline Deano2711
  • 1992 VR6
Re: Shocks
« Reply #9 on: 26 February 2012, 21:40 »
When I fitted my coilovers I swapped over my top mounts as they were nearly new and on the old springs and shocks I had to pull the shafts up manually to put the old top mounts on. I know the shockers were fine as I was running them upto the point I changed them  :wink:
