Author Topic: rocker cover/gasket and injector seals  (Read 3863 times)
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
« on: 25 February 2012, 19:42 »
Got a gen rockercover gasket and injector seals are these easy to change?bearing in mind im a bit of an engine novice lol.also to spray rocker cover could i degrease/clean with carb cleaner?and my last question i want to spray it black is it just a case of prime,spray,lacqer etc and would all these 3 need to be high temp paint.any recommendations?
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline navmk4gti
Re: rocker cover/gasket and injector seals
« Reply #1 on: 25 February 2012, 20:29 »
got mine done from dubunit seems like a easy job if you have the right tools and know what you are doing .. after seeing it done i would have a go myself  :smiley:
for the spraying rocker cover part you need loads of elbow grease and time .. was going to do mine but cba as i aint got the time aint even washed car in 3 months  :lipsrsealed:
Offline symsymma
« Reply #2 on: 25 February 2012, 20:48 »
What was that mate injecter seals or both :undecided:
Offline navmk4gti
« Reply #3 on: 25 February 2012, 21:16 »
rocker cover gasket mate  :smiley:
Offline Granta Gti
« Reply #4 on: 26 February 2012, 08:14 »
Injector seals are easy, I did mine on my ARZ. I spent the day taking the inlet manifold out and polishing it as it it was hanging from all the leaking fuel
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 26 February 2012, 10:05 »
inlet mani is easy to get off, takes about 20mins. The seats wind out, make sure you use some decent fuel/oil resistant sealant when you put the new ones back in. The injector O rings just roll off the injectors but be careful of the pintles (where the fuel sprays out)
I painted my inlet mani with a pot of high temp satin black paint from Halfords and brushed it on, came out quite nice in the end  :wink:
Injector seals changed on here
http://www.golfgtiforum.co.uk/index.php?topic=92175.40
Rocker gasket changed here
http://www.golfgtiforum.co.uk/index.php?topic=92175.50
and inlet mani painted here
http://www.golfgtiforum.co.uk/index.php?topic=92175.70
Offline symsymma
« Reply #6 on: 26 February 2012, 10:08 »
cool more jobs on the to do list before stage 2.cheers
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 26 February 2012, 10:11 »
All I did in the way of prepping the inlet mani was too degrease it and then a quick going over with a wire brush, paint is still there with no flaking off after nearly 2 years now  :smiley:
Offline Dave_IOW
« Reply #8 on: 26 February 2012, 11:19 »
I'm doing all this soon, injector seals dealer or eBay for you Wes?
Yellow spring finally in actuator lol
Not run it yet though, ill text you results..
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 26 February 2012, 13:46 »
The seats that fit in the manifold are dealer only mate, you won't need o rings as your injector kit had new ones. Just give me a shout whenever mate and pop round  :smiley:
