Author Topic: May have found a bargain 16v. Advice needed!  (Read 2286 times)
Offline SCO_VAG
  • www.ScottishVag.com
« on: 25 February 2012, 17:09 »
Hey guys!! just joined this recently as i'm in the process of looking at a 16v anni. The guy selling her originally wanted £900, I then got him down to £700.
So I went to see it and the bodywork is fecking immaculate, as is the interior. The car has sat for 3 months unused and runs quite rough which im hoping new spark plugs, oil etc should solve.
Also the steering is making a horrible squeaking noise and is putting up resistance to turn which I can only assume is the power steering pump? It also needs a new exhaust.
Given these problems I managed to get him down to £500 which I feel is reasonable as the thing is a minter bodywork wise, it also has a VW factory fitted push start button as it was an ex mobillity car.
Would the steering issue be very expensive?
Would a cheap n cheerfull ebay exhaust do the trick?
Very new to these Golfs so any advice is seriously mucho appreciated.
Cheers, John  :smiley:
« Last Edit: 25 February 2012, 23:53 by SCO_VAG »
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: May have found a bargain 16v. Advice needed!
« Reply #1 on: 25 February 2012, 17:27 »
sounds a absolute bargain mate, good work
show us some pics, does it still have the 160mph silver dials ?, genuine gear knob, BBS rims etc ?
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline dom
  • Back in a Mk4
« Reply #2 on: 25 February 2012, 17:40 »
Steering issue will either be the PAS pump or even just the belt, as for exhaust I'd look out of a second hand stainless steel one, either on eBay or forum classifieds.
As Brad says sounds like a bargain :cool:
VW BUSH
« Reply #3 on: 25 February 2012, 17:53 »
Check your power steering belt is not slipping, most probably got a coating of rust on it from standing.
Exhausts are to be had easy on this site and the bay, I sold a cat back for £40 not so long ago :rolleyes:
Pictures :smiley:
Offline Deano2711
  • 1992 VR6
« Reply #4 on: 25 February 2012, 18:05 »
Rip his arm off Mate.....rare car and these are minor issues. Once done will be worth 2/3 times what you pat with a bit of TLC. As said get some pics up Bud
Offline SCO_VAG
« Reply #5 on: 25 February 2012, 18:20 »
Really appreciate the replys lads!!
@F17BAD yeah mate it's totally standard VR6 splitter stitched steering wheel etc..
The guy selling it just wants rid of it because his missus dosent like older cars lol :grin:, Dont think he knows how rare these are.
Offline Dan_GTi8v
« Reply #6 on: 25 February 2012, 18:54 »
does the steering only make a noise when steering or all the time? It could be as simple as putting some power steering fluid in it, low fluid causes moans and harder steering
Offline SCO_VAG
« Reply #7 on: 25 February 2012, 19:05 »
Yeah mate it only makes a noise when steering.. could it be low in fluid?
How would I go about checking the level?
Cheers.
« Reply #8 on: 25 February 2012, 21:32 »
Would not be factory fit, someone has added that afterwards.
Offline SCO_VAG
« Reply #9 on: 25 February 2012, 22:01 »
Ok fair enough..
