Author Topic: What should I be replacing/inspecting before remap  (Read 1827 times)
Offline Chris#101
« on: 24 February 2012, 19:34 »
Bonjourno Amigo's, time has almost come to book in for my remap :cool:.
What should I be inspecting / replacing!? please add to the list in my head im thinking
*Engine oil
*Engine oil filter
*Inline fuel filter
*A tankfull of Tesco momentum 99 ron and redex
thanks
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline harlemex
Re: What should I be replacing/inspecting before remap
« Reply #1 on: 24 February 2012, 19:38 »
your insurance  :lipsrsealed:
Offline navmk4gti
« Reply #2 on: 24 February 2012, 19:39 »
redex  :huh: that is worst crap made by man  :grin:
give it a oil change if needs be .. scan for fault codes..check boost pipes any splits etc.. but wherever you get it remaped they will check pipes and scan it for you..if they dont then there sh!t
oh and get some v power in there tesco is to do shopping not fueling  :wink:
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
« Reply #3 on: 24 February 2012, 19:46 »
Maf,n75 and as said boost hoses and breather hoses a good remapping place would pick up on these before remapping.need a strong actuator and a good clutch as if its on its way out a map will finish it off.
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline Chris#101
« Reply #4 on: 24 February 2012, 19:49 »
and for arguements sakes I get there and theres is a problem with basic items such as hoses etc will they stock them as Its a good 300 mile trip  :lipsrsealed:
reading back on that I guess I really need to be asking r-tech  :grin:
Offline symsymma
« Reply #5 on: 24 February 2012, 20:01 »
had mine done at r tech,when i rang and asked first of all they said common probs were maf,n75 and actuator so i got new maf and n75 and took chance on actuator.but id already fitted uprated boost hoses you could prob get a set for £70 a good investment imo.like you say ring them and see wot they say.i think they have mafs and n75 valves there.
Offline shaft69
« Reply #6 on: 24 February 2012, 20:34 »
Tesco 99 cool read indepth article some time ago on fuels tesco 99 actually gave better performance output than v-power only bp ultima out performed it. Were using golf mk5 gti  and bmw m5,run tesco its all cool.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline cullygti
« Reply #7 on: 24 February 2012, 20:37 »
 recirc valve for 007p pcv pipes boost pipes etc catch can is a good one to do and delete pcv system its what r-tech recomended to me maf and n75 as said  :cool: good exhaust helps to and a silicone tip   :wink:
Offline Rhyso
« Reply #8 on: 24 February 2012, 20:45 »
The car
Offline richw911
