Author Topic: What should I be replacing/inspecting before remap  (Read 1823 times)
Offline Chris#101
Re: What should I be replacing/inspecting before remap
« Reply #10 on: 24 February 2012, 21:17 »
well thats a good headstart  :cool:
Current spec is
*AUQ180 80k miles
*Forge Tip
*3" turbo back non res exhaust system
*Toyosport FMIC
*Uprated Re-circulating valve
*Toyosport Cold air induction kit
So hopefully fingers crossed we shall see some good bhp/torque figures  :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 24 February 2012, 21:42 »
boooooost leaks  :grin:
R-Tech might stock the items if you need them, I know Nick tried ringing round loads of places to find me a MAF but couldn't get a genuine one first time I went up so I had to go home with half a map lol
Offline Chris#101
« Reply #12 on: 24 February 2012, 22:16 »
not gonna lie feeling pretty nervous now after hearing all this  :grin:
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
« Reply #13 on: 24 February 2012, 22:19 »
i wont lie i was nervous to mate.do you have a boost guage fitted?do you think the cars boosting ok now and running ok?
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline cullygti
« Reply #14 on: 24 February 2012, 22:25 »
mine was boosting to what it should have been standard but still had a boost leak somewhere and faulty maf so checking them for corrosion before hand will help  :wink: still car was great and power was awsome but now the leak is done its like a new map thats even better  :laugh:
Offline Chris#101
« Reply #15 on: 24 February 2012, 22:27 »
Atleast its not just me then  :grin:
I do indeed bud, peaks at about 10/11psi then settles down to 9psi!
As far as I know the car is healthy, I do have one fault code (an exhaust emmisions one) but thats only ever started appearing since iv had the 3" turbo back straight through pipe put on so ive put it down to that!?  :lipsrsealed: but I hear on a the stage 2 custom remap they alter/delete the lambda/emmisions readings!?
Offline symsymma
« Reply #16 on: 24 February 2012, 22:39 »
Boost sounds ok,wouldnt know about ur emissions thing.wouldnt hurt to fit a new gen maf though mate
