Author Topic: Universal spacers....how the hell do you line them up?  (Read 1666 times)
Offline dom
  • Back in a Mk4
« on: 23 February 2012, 16:55 »
As per title, I've got some 5mm universal jobbies to prevent my wheel from hitting my coilovers. How the hell do you line them up when fitting?
If I rest them on the hub I can't get the bolts lined up, if I put them on the wheel with the bolts through then its impossible to get the bolts into the hub without one or more falling out & the spacers moving :angry:
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Re: Universal spacers....how the hell do you line them up?
« Reply #1 on: 23 February 2012, 17:12 »
Put 2 or 3 bolts through with spacer attached to wheel, then put a few bits of masking tape to hold it in place, remove wheel bolts then fit? Then when done, rip masking tape off..
Offline jonrandom
« Reply #2 on: 23 February 2012, 17:23 »
+1  on using masking tape.
Offline tweed
« Reply #3 on: 23 February 2012, 17:32 »
buy good spacers
I got 5mm tpr (taperpro) I put them on the hub, line up the holes and bolt wheel up.
I put some sh!t spacers on my mates car and had to drill the holes in places to get them to fit.
Offline jonrandom
« Reply #4 on: 23 February 2012, 17:36 »
I needed bigger so got 20mm hubcentric ones now so no problems getting everything lined up.
Offline clipperjay
« Reply #5 on: 23 February 2012, 17:40 »
buy good spacers
Did you re-balance the spacer after drilling holes  :laugh:
Offline dom
  • Back in a Mk4
« Reply #6 on: 23 February 2012, 17:52 »
All sorted now after a lot of swearing, I'll stick some proper ones on soon but I had to get some on ASAP as my tyre was rubbing on my coilies:
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #7 on: 23 February 2012, 18:18 »
Ouch  :huh:
And swearing always helps get stuff done  :grin:
Offline tweed
« Reply #8 on: 23 February 2012, 19:37 »
buy good spacers
Was only shavings prob less than half a gram
