Author Topic: Sump plug stuck, need help! EPIC FAIL ALERT, DO NOT MISS!  (Read 10199 times)
Offline SoundillusioN
Re: Sump plug stuck, need help!
« Reply #10 on: 23 February 2012, 10:13 »
i did think about syphoning some out.......lots of ideas now!
Really just need to put more pressure on the ratchet....as long as the car doesn't fall on my face in the process...
Thanks,
Scary!.... get yourself some ramps!
Offline Tomonator1985
  • Low 'n' Slow
« Reply #11 on: 23 February 2012, 10:38 »
[/quote]
LOL! got it on axle stands so i'm jsut being a wimp
*MK2 Golf GTI 16v Small Bumper*
Offline Sam
  • Sam I am
« Reply #12 on: 23 February 2012, 10:46 »
[/quote]
Slip a couple of old wheels under there aswell, thats what I normally do
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #13 on: 23 February 2012, 11:38 »
1. Could he just not disconnect the breather , put it into a bottle and turn the engine over?
2. Remove the dipstick tube and syphon it out?
3. Remove the oil filter, release some oil so it's drivable, and then take it to a garage.
4. Andywash.
3 seems likes the sensible option, no?
  • Low 'n' Slow
« Reply #14 on: 23 February 2012, 11:47 »
4. Andywash.
3 does seem to be the easiest, but i need to try the bolt again as i don't want to be defeated!
Offline Diamond Hell
  • Opinions я Us
« Reply #15 on: 23 February 2012, 13:12 »
Ooh ooh an Andywash option.
it's been a while.
I definitely vote Andywash, with a side order of man the f*ck up and undo it.
  • Low 'n' Slow
« Reply #16 on: 23 February 2012, 14:27 »
it's been a while.
............................................I'm sad to say i agree.....
Offline Seanl
« Reply #17 on: 23 February 2012, 14:37 »
As you've said, just take the filter off and ditch the oil from there. Think its almost half a litre in there alone. Put back on, job done.  :smiley:
Offline theclash
« Reply #18 on: 23 February 2012, 15:05 »
If you changed the oil and overfilled it surely you must have had the sump plug off ?
Why bother f@@@ ing about with filter siphon etc just undo the plug it will have to come out eventually anyway.
Offline clipperjay
« Reply #19 on: 23 February 2012, 15:23 »
Dont drive it mate overfilled it can cause badness you don't want to get fixed!
I say Jons suggestion of sucking out of dip stick hole a good option not sure how much oil is in the head but taking the oil fillter off gravity will let is bowls out over you!
