Author Topic: fuse keeps blowing, urgent  (Read 4058 times)
Offline clancy
Re: fuse keeps blowing, urgent
« Reply #10 on: 20 February 2012, 18:29 »
Ok I checked behind the rear light and everything seems ok, no rust or damp and everything looked ok and in place.
I'll check the door wiring next, is there a quick guide for the door cards ? Can't see much on them and don't wanna snap something
Cheers guys
MK3 GTI 16v
Offline clancy
« Reply #11 on: 21 February 2012, 15:24 »
One other thing that might be of importance is there was an aftermarket radio in the car which I removed, when I put my one in it had no power going to it, so I tried the old one which still didn't work. I took it to a car audio place who said something about a switch on the ignition? And that instead of replacing it it was easier and cheaper etc to just wire the radio to the ignition. Something along them lines.
Not sure if that's relevant, thought it might be as it wasn't getting any power. But it works fine now even with the fuse blown. Also does anyone know what size fuse is supposed to be in the slot? Cheers
MK3 GTI 16v
Offline madmanmart
« Reply #12 on: 21 February 2012, 22:38 »
I think im right in thinking that the radio and central locking share the same fuse.
So if the audio place has bodged and bipassed the fuse then this could also be a problem.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline clancy
« Reply #13 on: 22 February 2012, 01:26 »
i was previously told the radio fuse was 22 ? not sure whats what really as none of them are labelled
getting on my nerves now, i dont know what they did to the radio but it works perfectly now. he said theres something on the ignition barrel that lets accessories run when the keys in with the ignition off or something and that wasnt working. not really sure what he was on about
MK3 GTI 16v
Offline Screech16v
  • MK3 20vt AGU
« Reply #14 on: 22 February 2012, 21:47 »
http://www.a2resource.com/electrical/CE2.html
Fuse locations at bottom of page  :smiley:
