Author Topic: fuse keeps blowing, urgent  (Read 4057 times)
Offline clancy
« on: 19 February 2012, 12:39 »
hi guys after some help if possible. fuse 21 keeps blowing, am i right in thinking thats the sunroof & central locking ? well i presume so as they are what doesnt work when its blown.
it had a 15 fuse in it which was blown when i got the car, replaced it and all was good for about 2 days. blew again.
so, tried a bigger fuse, as soon as the contacts touched it blew, tried another one and that blew. there just blowing as soon as it touches the fusebox.
any ideas on what could cause this ? massive pain in the ass with the central locking not working. my boot only locks using the central locking so my car is not secure without it working.
any ideas would be great guys, cheers
MK3 GTI 16v
Offline clancy
Re: fuse keeps blowing, urgent
« Reply #1 on: 19 February 2012, 12:43 »
and can anyone take a photo or something if all the relays above? im fairly sure i have an empty slot like one is missing ? :S
MK3 GTI 16v
Offline Seanl
« Reply #2 on: 19 February 2012, 13:17 »
Its obviously shorting out somewhere. You'll need to trace the wiring back, and see if you have exposed core anywhere touching to earth, or any other wires. Something may have snagged somewhere, or the insulation has melted together on something.  :smiley:
Offline clancy
« Reply #3 on: 19 February 2012, 13:31 »
thanks for the reply:) okidoke, where would you think is best to start looking ? central locking wiring ?
only thing im thinking is, is it the boot causing a problem maybe ? as it doesnt manually lock, only with central locking. like the key physically wont turn in the lock.
MK3 GTI 16v
Offline madmanmart
« Reply #4 on: 19 February 2012, 14:31 »
Have a look at the plug connection to the central locking pump. Its located under the O/S rear light.
Damp can get in and cause problems with them.
The boot lock problem will be unrelated...........
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline tweed
« Reply #5 on: 19 February 2012, 15:29 »
I second this
Offline Jasikasisback
« Reply #6 on: 19 February 2012, 19:01 »
yeah the central locking is really funny sometimes...my driver's side door would not lock unlock via key one morning...drove around and then it decided to work...i'm sure it is due to dampness...now my boot lock wont unlock using a key (wont even turn the lock) yeah it's not related, but hey welcome to the joys of owning a volkswagen...!This is why the Germans' tanks froze outside of Stalingrad...they just can't design a proper electrical system!!
Offline beno88
« Reply #7 on: 19 February 2012, 19:45 »
the locking assembly on the boot may possibly be corroded up, hence why key wont do anything, also when you check your central locking pump out. if its damp take the rears light cluster out and make sure its not rusted out and water is getting in. had this problem with mine when i first got it.
Offline clancy
« Reply #8 on: 19 February 2012, 21:13 »
ok thanks guys, will investigate tomorrow morning and let you know. need a new pack of fuses  :laugh:
MK3 GTI 16v
Offline javalin
« Reply #9 on: 20 February 2012, 10:05 »
also might be worth checking drivers door, as its common for the loom to suffer with the repeated open/close.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
