Author Topic: Can't reach all the bolts when changing sump :(  (Read 2366 times)
Offline b3an6030
« on: 18 February 2012, 22:37 »
Well as titled really, I went to Change my sump a little while ago and I couldn't get access to all of the bolts. I think there was maybe 2 bolts I couldn't get access to.. I've had a good search on different forums and the net to try and find some answers but couldn't find anything :(
Anyone got any info on how to get to them?
I ended up paying a garage and it was a insane amount to get sorted...
It was a 1.6 8v
Thanks in advance
Offline Jasikasisback
Re: Can't reach all the bolts when changing sump :(
« Reply #1 on: 18 February 2012, 23:14 »
Cant see anhonest mechanic charging amy more than 20 minutes of work time.
Sometimes bolts are a pain to find. Thays why vagcat are indipsensible!
Offline Dan_GTi8v
« Reply #2 on: 18 February 2012, 23:56 »
why cant you get to them whats in the way?
Offline tweed
« Reply #3 on: 19 February 2012, 00:38 »
maybe you need some more tools?
Offline Seanl
« Reply #4 on: 19 February 2012, 08:59 »
Your obviously referring to the 2 bolts on the gearbox side of the sump. Absolute b!tch to get to, but can  be done with a flexi extension bar for the ratchet (dont know the proper name but heres one similar)
http://www.ebay.co.uk/itm/UNBRANDED-38197-150MM-FLEXIBLE-SCREWDRIVER-EXTENSION-/260938314680?pt=UK_Home_Garden_PowerTools_SM&hash=item3cc122b3b8
 :smiley:
Offline b3an6030
« Reply #5 on: 19 February 2012, 11:31 »
Yea as in the last post on the gearbox side. I will get a photo this week to show you.. Have you managed to get the bolts off with one of those flexi things. It looked pretty much impossible to reach with out moving the gearbox out of the way or something..
Offline todd
« Reply #6 on: 19 February 2012, 11:32 »
Take the plate off thats attached to the gearbox it's half moon shape it stops stones and excess water getting into the bellhousing then you should get them easy
Offline b3an6030
« Reply #7 on: 19 February 2012, 11:53 »
Thanks Todd, I did read in the Haynes about taking something off.. But I couldn't see where you actually take it apart :/ and typically that's the only thing that wasn't pictured in the Haynes.
I will get under it this week and try and get some pictures..
Thanks
« Last Edit: 19 February 2012, 11:55 by b3an6030 »
Offline Seanl
« Reply #8 on: 19 February 2012, 13:12 »
Its just a thin alloy plate that sits over the gap and is secured by 2 bolts. Its still a twit to get at as the angle is funny (bends one way, then the other) iirc, should be able to get it off with the flexi though. I took mine off with the engine and GB out though, but I need this for the Raddo when I get round to doing it.
Offline Dan_GTi8v
« Reply #9 on: 19 February 2012, 13:18 »
I know the bolts you mean, we had trouble getting some off a mates sump, we even had one of those flexi things but they were on so tight it wouldn't work. In the end we had to take the gearbox off
