Author Topic: Can't reach all the bolts when changing sump :(  (Read 2368 times)
Offline Jasikasisback
Re: Can't reach all the bolts when changing sump :(
« Reply #10 on: 19 February 2012, 18:57 »
i hope you didn't take the gearbox off but just took the gearbox guard off...I changed the transmission oil and filter recently with a mate and wouldn't even dream of taking the gearbox off as that would be  :laugh:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #11 on: 19 February 2012, 19:00 »
I can remove a sump in 20 mins max (iv removed loads now as i always change Pick up pipe)
i use a Allen key with the Ball end.
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Seanl
« Reply #12 on: 19 February 2012, 19:09 »
When I did my golf one, the original bolts were all just 10mm (I think) bolts. I bought a full set of replacements, and these had the allen key fitment within the bolt though. Think that could be hit and miss.
Offline F17BAD
« Reply #13 on: 19 February 2012, 21:27 »
all ones iv done have had the alen hole in the centre, use a small bar on the allen key, no probles at all..
remember on replacement to torq correctly and use the VW silicone paste   :nerd:
Offline Dan_GTi8v
« Reply #14 on: 19 February 2012, 21:49 »
the one we did wasn't on a mk3 so probably slightly different, but there was deffinatly no way of getting to the bolts without taking the gearbox off. Was in a mk1 it started off as an abf I think but has all kinds of different engine parts all over the place trust me we did lots of research to try and find another way :P
Offline Ninj
« Reply #15 on: 19 February 2012, 21:54 »
Agreed! Pain in the ar5e. Mine are torx bolts and the only I managed those two was with a long torx but coming to put them back in I could do nothing to avoid cross threading them  :rolleyes:
I think maybe a 3/8 or 1/4 bit holder might work, mine are 1/2" and it's the bit holder which gets stuck
