Author Topic: Suspension difference question? Picture Inside now  (Read 2745 times)
Offline performancevw
« on: 18 February 2012, 15:14 »
hello boys and girls
can someone tell if MK3 Golf GTI VR6 standard suspension are all the same for a 1.4 1.6 1.8?
Are GTI VR6 standard suspension slightly lowered than a 1.4 1.6 etc or are they all the same height and would a GTI / VR6 suspension fit on a 1.4 straight?
Cheers :smiley:
« Last Edit: 19 February 2012, 16:24 by performancevw »
Offline dom
  • Back in a Mk4
Re: Suspension difference question?
« Reply #1 on: 18 February 2012, 15:31 »
The suspension is all the same fitment so you'll be able to put gti/vr6 suspension on a 1.4 or 1.6, however both will be lower than standard.
I'm sure someone will correct me if I'm wrong but I think that the VR6 suspension will sit slightly higher at the front than Gti suspension will, due to the Vr springs being designed for the heavier engine.
Offline mcgee9t2
« Reply #2 on: 18 February 2012, 15:41 »
this is the way i understand it to be too
Offline tweed
« Reply #3 on: 18 February 2012, 16:07 »
Surley the vr6 has a stiffer spring rate.
Offline SoundillusioN
« Reply #4 on: 18 February 2012, 22:22 »
This...^^^
Fitment is one thing but dampening/spring rates can differ between engine fitment and models.  I'm sure that between say VR6s, TDIs and 1.4s there will be a considerable differences and therefore it is usually recommended that suspension is fitted for the correct model.
« Reply #5 on: 19 February 2012, 09:37 »
Cheers :smiley:
Standard mk3 suspension is crap no matter what engine, all the spring rates are different depending on what engine.
Better in the long to save up and get the correct kit, gti is only 15mm lower btw.
« Reply #6 on: 19 February 2012, 10:07 »
cheers guys just wanted to know the difference so will be getting proper lowering suspension in the longer run as currently it sits on standard chopped springs  :embarassed:
« Reply #7 on: 19 February 2012, 13:21 »
Bad boy. Tut.
« Reply #8 on: 19 February 2012, 16:24 »
Offline X01X
« Reply #9 on: 21 February 2012, 22:52 »
It looks nice sat like that but i would sort out the suspension properly, chopped spring = bad idea
