Author Topic: Central Locking Pump  (Read 4480 times)
Offline Mk3 16v Anniversary
« on: 26 September 2003, 13:19 »
Chaps
          Got another problem & was wondering if you can help.  When unlocking the car using the alarm fob (haven't tried with the key yet) I can hear the pump start up and the car unlocks.  The problem is that the pump carries on pumping for what seems like an eternity until it eventually stops, however the pump does stop immediately when the key is turned in the ignition.
I have removed the pump a couple of times, fiddled around with it and the put it back. It then seems OK for about 5 minutes before playing up again.
Anyone got any ideas?
Thanks in advance.
« Last Edit: 26 September 2003, 13:21 by Mk3 16v Anniversary »
golfvr6
Re:Central Locking Pump
« Reply #1 on: 27 September 2003, 17:49 »
Are all the doors locking properly? if not then you have a vacuum leak in the system, probably a hose has come off where the door opens.
Offline modulater
« Reply #2 on: 28 September 2003, 02:53 »
does it lock in the same manner?
« Reply #3 on: 28 September 2003, 15:46 »
All the doors lock ok and the pump seems fine, problem is just that when unlocking the car the pump takes ages before is shuts down.  I have heard from a friend that it could be a vacuum leak somewhere in the system.
Offline richandhazel
« Reply #4 on: 30 September 2003, 22:46 »
I reckon you have a vacuum leak too. I did have a troubleshooting guide for the central locking system, I'll have to try and dig it out again.
« Reply #5 on: 01 October 2003, 13:04 »
The problem now seems to be getting worse so that would be great.  Thanks.
« Reply #6 on: 01 October 2003, 19:44 »
Does this help:-
http://homepage.ntlworld.com/richandhazel1/gti/profix/electrics/main.htm#central
Its from the Mk2 manual but I would imagine its very similar.
Offline thehibs
« Reply #7 on: 01 October 2003, 19:55 »
i have a 4dr gti and where the vacuum pipe goes into the passenger back door frame keeps popping out thus not locking doors etc !! you must have a leak somewhere in ya pipes !! or a dodgy connector somewhere !!
« Reply #8 on: 03 October 2003, 09:57 »
Thanks for digging that out.  I'll have a go at sorting it over the weekend.  If I still have no luck i'll get my mate to look at it when he services the car in a week or two's time.
Offline Overseer
« Reply #9 on: 15 October 2003, 20:37 »
if its getting worse it can knacker the pump, happened to me on my old polo
