Author Topic: Dropping revs.......  (Read 1155 times)
Offline gtiballs61
  • Wanted-nearside wing in lp3g(flash red)
« on: 16 February 2012, 17:53 »
Mk3 8v Gti AGG 1996
As per title,keeps trying to cut out.
On the motorway kept juddering all through the gears, couldn't maintain a stable speed without it juddering.
Just before christmas it had
Ht leads
plugs
dizzy cap
rotor arm
oil change
pipercross air filter
temp sensor
Heads now baffled,got me mechanic mate having a look in the morn,hopefully can seek the source of the problem for me. :cry:
Offline Khare
  • The bear that khares
Re: Dropping revs.......
« Reply #1 on: 16 February 2012, 17:55 »
coil? ecu relay? fuel pump relay?
Offline Luke1981
« Reply #2 on: 16 February 2012, 19:01 »
I would agree with khare. Let's hope its just a relay which is cheap as chips to replace. Let us know the result
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline gtiballs61
« Reply #3 on: 16 February 2012, 20:09 »
I'm thinking more on the electrical side.
I did forget to mention it did backfire a couple of times :undecided:
Offline Khare
« Reply #4 on: 16 February 2012, 20:19 »
So coil, ECU and fuel pump relays are not electrical?
Check spark plugs also. Mine had similar symptoms to yours ie: not being able to maintain speed, juddering in any gear, backfiring. Turned out to be coil (died on the way home from a dyno). RAC came to the rescue, sold me a new coil and it's not been a problem since.
Offline Martz
« Reply #5 on: 17 February 2012, 12:27 »
Does idle inconsistantly? Might be a case of cleaning up the icv???
Offline gtiballs61
« Reply #6 on: 18 February 2012, 14:54 »
I was agreeing with you :wink:
« Last Edit: 18 February 2012, 14:57 by gtiballs61 »
Offline gtiballs61
« Reply #7 on: 18 February 2012, 14:57 »
So far i have changed the ecu relay and fuel pump relay.
Still no joy :sad:
I have just fished out my little vag com handeld thingy,just cant find the code book :embarassed:
Will update shortly
Offline Edwh0re
« Reply #8 on: 18 February 2012, 19:39 »
Crank Sensor.
