Author Topic: Front wishbone query....2.0 Gti  (Read 1640 times)
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« on: 14 February 2012, 12:11 »
Can anyone confirm if the rear bush on the front wishbones require a sleeve or is it the clamping force that keeps it centralised? The hole diameter in the bush is larger than then bolt used to secure it and know that Mk2's use a sleeve but mine definately didn't have any when I removed the old ones.
Many Thanks.
Re: Front wishbone query....2.0 Gti
« Reply #1 on: 14 February 2012, 13:36 »
It should have a sleeve in it.
Offline Lurky
« Reply #2 on: 14 February 2012, 15:01 »
Offline Gti_Jamo
« Reply #3 on: 14 February 2012, 18:25 »
Its just that the subframe has a U shaped recess on it to stop side to side movement and the tightening of the bolt holds it in place. Definately had none when they came out and I suspect my old ones were the originals.
Anyone got a part number or know a place I can buy them?
Offline mad4vws
« Reply #4 on: 14 February 2012, 18:29 »
shoud have sleeves in but ive seen people use a short peice or copper pipe 15 mm .
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline Gti_Jamo
« Reply #5 on: 14 February 2012, 18:41 »
Done a bit of reading and I keep coming across people saying that the Mk3 does not have these sleeves from the factory and the sleeves you can buy are merely for centralising the bush into position so not essential. The recess in the subframe along with the clamping force is what keeps it in position.
« Reply #6 on: 14 February 2012, 20:08 »
I think it is still better to have the sleeve if you can.
