Author Topic: mapping ko4'd agu  (Read 111648 times)
Offline DMcK
  • Red MK4 Golf 1.8T. Unmolested...Soon to change!
Re: mapping ko4'd agu
« Reply #290 on: 18 March 2012, 20:58 »
What bhp would i see from a K03, catback and a remap?
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #291 on: 18 March 2012, 21:02 »
probs around the 180bhp mark depending if the actuator is strong. Would recommend fitting a Forge 007p recirc valve and maybe get a pipercross panel filter or CAI to get more air to the turbo.
Offline Hulmie
« Reply #292 on: 18 March 2012, 21:03 »
niki - in the dry its a wepon  :laugh:
wrong siide on 140  :lipsrsealed: :lipsrsealed:
naughty
Offline DMcK
« Reply #293 on: 18 March 2012, 21:05 »
Yeah i will get a forge DV. I've recently just put in a pipercross panel filter. 180? That it. Might have to try get my hands on a K03s when i have money.  :grin:
Offline Hulmie
« Reply #294 on: 18 March 2012, 21:18 »
without the filter and recirc valve.
I was getting 198bhp with 3" downpipe n de-cat, milltek back anni style system, pipercross filter, forge TIP and forge 007p with a r-tech remap.
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #295 on: 19 March 2012, 17:16 »
Just found out the BAM will also crack 300bhp :grin:
306bhp @5200rpm @ 1.29bar with less than 80% N75 duty on a stock actuator with 4 turns of added pre load.
EGTs 820 @ 6800rpm on the dyno, just need to do some road tesing to fully load the engine and injectors.. :grin:
 01455 617233
Offline barrym381
« Reply #296 on: 19 March 2012, 17:43 »
is this with similar bits to toby :smiley:
Offline RTechUK
« Reply #297 on: 19 March 2012, 17:44 »
Apart from the large port head and this is running me7.5 ecu which is a little be harder to run a good sum of timing advance
 01455 617233
Offline Hulmie
« Reply #298 on: 19 March 2012, 18:44 »
turning into a K04 wizard now nick.
Offline Toby
  • Car - less
« Reply #299 on: 19 March 2012, 18:47 »
hawt stuff! whens F17 BAD geting booked in for a REAL MANS REMAP!  :evil:
Currently down under
