Author Topic: mapping ko4'd agu  (Read 113287 times)
Offline Toby
  • Car - less
mapping ko4'd agu
« on: 13 February 2012, 19:38 »
hey nick!
iv got hulmie's old white mk4!
gone for the ko4 set up, thats being fitted this week. which is,
K04-022
standerd ko4 manifold
oil feed and water feed and both returns
3" decat and downpipe
badger 5 V2 80mm Tip
red top injector's - not fitting til mapping.
LCR fuel pump.
Big front mounted intercooler with atleast 2.5" pipework
im going from a stage 2 r-tech Remap with the old ko3s
how long am i looking at leaving it with you? and what price's?
Toby
Currently down under
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: mapping ko4'd agu
« Reply #1 on: 13 February 2012, 20:24 »
Get the new Relentless Ko4 manifold, its the new must have item for 2012.   I am pushing a AGU k04-hybrid to 310bhp with less than 14psi of boost and no major heat build up, where the stock manifold would need 20+psi of boost to make the same power.
http://www.facebook.com/#!/groups/125246960928520/
Only think you missed off the list is the MAF?
2.5" IC pipes is a must have as I found the limits of 2" 240bhp with 20psi of back pressure...lol
We will start from scratch with the mapping and work in steps, day 1 check and test all hard ware and pressure tests ect, day 2 tune the car to the limits of the stock maf and injectors to give base line readings to work from, then injectors and MAF are fitted,  day 3 scale fuel and MAF maps and start to tune, day 4 map tweaking and road test logging plus final dyno runs.   All the work will be carried out between booked jobs and free slots.
If your booking for March  we will have our new OLS300 system installed and your remap will be a live emulated remap, where our laptops will connect direct to the ecu so we can make map calibrations in real time, which is going to make our maps even more refined.
SP3 Live Custom Map    = £390 (bigger turbos)
 01455 617233
Offline Toby
  • Car - less
« Reply #2 on: 13 February 2012, 20:33 »
i have the maf  :grin:
ill go for 3" intercooler pipework!
i think i have a tublar manifold, ill have a look what make it is later,
so if i bring it up on the 5th of march, and come back up on the 10th, would that leave you enough time?
it will defo be in march, as were going to Ultimate dub's on the 11th, but staying in leister on the saterday ( with family)
if you have them date's free then thats cool ill book the days off work, and book the train ticket's.
Offline shaft69
« Reply #3 on: 15 February 2012, 21:30 »
Too cheap nick!!  :grin:
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Toby
  • Car - less
« Reply #4 on: 15 February 2012, 22:15 »
noo!!
also! all booked in, train tickets booked, for return home on the sat, and the journey up there! and a premier in for the friday night also!
Cant wait!!
Offline blade4real2004
  • golf gti with a touch of .:R
« Reply #5 on: 16 February 2012, 16:57 »
ill be looking at getting mine booked  in soon to nick just got my tax and mot due so will get them outta the way and will be looking at getting the mapping done real soon after that
k04s | jabba cai | stage 2 (Rtech) | forge 007p | forge boost hose set |forge tip | THS fmic | gen r line kit | bbs ch | TT short shift | R32 vents | full stainless | decat | auto windows | mk5'd boot
need a scan or mod with vagcom & vagtacho PM ME (south wales area)
my build thread - http://uk-mkivs.net/forums/t/236415.aspx?PageIndex=1
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #6 on: 05 March 2012, 17:20 »
Toby
Good to see your taking my old car further. Hope its still serving you well mate Still miss Her
Offline westallc
« Reply #7 on: 05 March 2012, 20:54 »
3 inch pipe work will be to big surely!!!!
im running 57mm turbo to intercooler and 60mm to throttle body thats on a big turbo setup
i know of cars in america running 700bhp on 60mm pipe work !!!
Offline Toby
  • Car - less
« Reply #8 on: 06 March 2012, 11:01 »
Iv got 2.5" intercooler pipework.
Offline MaXXeH
  • Golf MK5 GTI
« Reply #9 on: 06 March 2012, 15:10 »
is your car there now?
