Author Topic: rear axle  (Read 1314 times)
Offline stuupnorth
rear axle
« on: 20 May 2005, 22:53 »
Hi
can anyone help??
I'm changing the rear axle bushes on my '93/93 gti
is there easy way to do it?? I've manged to get the drivers side out no problem(well so far anyway!!)
and how easy is it to remove the 'load -dependent valve' as I'm having trouble removing it
cheers for any advice
Stu
Offline mr wong
Re: rear axle
« Reply #1 on: 26 May 2005, 22:08 »
NOT EVEN TRIED IT MYSELF, BUT THE MECHANIC WHO DOES MY CAR SAYS ITS A BARSTEWARD OF A JOB!
Offline GTI EDITION (aka LTD)
Re: rear axle
« Reply #2 on: 26 May 2005, 22:38 »
I totally agree. I have done this job on various VWs ,not too badder job on the mk2s  but mk3s and Corrados are a right pig and a half when the countersunk Allen bolts/screws get corroded into the pressure regulator and then round out when you try to undo them. F--KING STUPID IDEA !!. Why they didn't use ordinary 13mm bolts like on the mk2s is beyond me!! :angry:
The only way I have have found is to VERY carefully drill them out  ( you will probably need a good stock of spare drill bits)
If you cannot get new Allen bolts ,when refitting the regulator, you can use 13mm bolts with 2-3 washers that fit inside the recess as a temporary measure until you can get the right bolts  don't froget to grease them up well for next time (if there is a next time!) :wink:
And as for the bushes .Getting them out is the easy bit its getting them back in in the right position which is the sod (there is a special tool for it although the dealership I worked for were too tight to get on so I had to fabricate one myself!) :angry:
« Last Edit: 29 May 2005, 16:52 by VENTO GTI EDITION »
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
