Author Topic: Breather filter location  (Read 2560 times)
Offline DMcK
  • Red MK4 Golf 1.8T. Unmolested...Soon to change!
« on: 10 February 2012, 18:51 »
I can't see a breather filter on my car. Where is it located if it was one. I have a 2000 Golf 1.8T.
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
Re: Breather filter location
« Reply #1 on: 10 February 2012, 18:55 »
AGU engine codes dont have them mate.
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline DMcK
« Reply #2 on: 10 February 2012, 18:58 »
2 birds with one stone. I wanted to know what engine i had to. Cheers. Whats the difference between 2? AGU and AUM i think it is?
Offline symsymma
« Reply #3 on: 10 February 2012, 19:05 »
AGU is cable operated throttle and a k03 turbo,AUM is drive by wire and has a k03s turbo.an AGU has stronger internals ull get 190 -200 bhp with a mapped agu,and 200-215 bhp with a mapped aum with standard turbo's.the engine code is on sticker under carpet in boot next to spare wheel or if u remove engine cover is stamped on front left hand side.
Offline DMcK
« Reply #4 on: 10 February 2012, 19:08 »
Well that's a big insight. Cheers. So AUM is better to have or both have pros and cons?
Offline symsymma
« Reply #5 on: 10 February 2012, 19:10 »
Am not 100 percent sure when they changed from agu to aum if someone could clarify change over year plz :smiley:
Offline symsymma
« Reply #6 on: 10 February 2012, 19:13 »
pros and cons for both mate you could have a big debate on whats better lol.coil packs are a lot better on an AGU can tell you that for certain lol.
Offline symsymma
« Reply #7 on: 10 February 2012, 19:16 »
Put a k03s on an AGU cant go wrong same fitment,can hold boost a bit higher and for longer on a k03s.
Offline DMcK
« Reply #8 on: 10 February 2012, 19:31 »
Ok cheers. Will have to have a read up some where on them.
Offline navmk4gti
« Reply #9 on: 10 February 2012, 19:32 »
difference agu and aum is on a agu you can boot it switch car off and go insideyour house.. on a aum you have to lift the bonnet push down your coilpacks then go in  :lipsrsealed:
