Author Topic: reverse noise :(  (Read 842 times)
Offline simonh285
reverse noise :(
« on: 09 February 2012, 22:58 »
hi, iv had my mk4 1.6 16V a few weeks and love it! iv noticed that when reversing there is a knocking noise coming from the front of the car, id say from the gearbox or drive shafts. the faster i reverse the faster the knocking gets.
iv found out that putting the car in reverse and letting it roll back with the clutch pushed down makes the noise but letting the car roll back in neutral stops the noise. the problem only happens in reverse so im guessing its to do with the reverse gear?
i just wondered if anybody knew of this problem or would be able to give me a few pointers as iv read the gearbox are a ball ache on these golfs :(
many thanks
simon
Offline james2
  • No scammers please.
Re: reverse noise :(
« Reply #1 on: 09 February 2012, 23:02 »
engine mounts.Put in reverse and hit bitting point with hand brake on. Get someone to look at the engine and see if it moves.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline simonh285
« Reply #2 on: 09 February 2012, 23:06 »
ahh good shout i didn't think of that at all! roughly how much movement would i get if it was the engine mount?
« Reply #3 on: 09 February 2012, 23:41 »
Or could be a gearbox problem.
Offline mick ov mids
« Reply #4 on: 10 February 2012, 02:01 »
i'd put my money on it being a gearbox problem .
[img width=500 height=200]http://i836.photobucket.com/albums
Offline simonh285
« Reply #5 on: 10 February 2012, 07:23 »
Ok so if it was a gearbox problem is a a problem that will be fine to drive around with for a few months or is it going to cause me even bigger problems?
Thanks again
