Author Topic: wheel bearing replaced but still makes noise?  (Read 2359 times)
Offline sam_xr2i
« on: 07 February 2012, 19:39 »
As above really on mk3 golf gti 8v. bearing is nice and tight and plenty of grease, any suggeations?
Offline Screech16v
  • MK3 20vt AGU
Re: wheel bearing replaced but still makes noise?
« Reply #1 on: 07 February 2012, 19:43 »
Its not supposed to be tight mate,just past finger tight at most.
Offline Li-D
« Reply #2 on: 07 February 2012, 19:44 »
Maybe other side needs doing too, happened to me before haha
Mk3 Golf TDI - GTD replica in progress....
OEM CHIPPED....
NO POKE WITHOUT SMOKE!
Offline sam_xr2i
« Reply #3 on: 07 February 2012, 19:50 »
  :laugh:
il double check tightness but it shudnt be to tight, all other bearings have been replaced aswell but o/s rear is still playin up, the noise is driving me mental lol
VW BUSH
« Reply #4 on: 07 February 2012, 19:59 »
Rear callipers sometimes stick and sound a bit like a bearing.
As said bearings should be done up by hand until 99% of play is removed, they wont last long if too tight :smiley:
Retro_look
« Reply #5 on: 07 February 2012, 21:06 »
castellated tyres give the same noise symptoms as a wheel bearing, you checked your tyres?
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 07 February 2012, 21:10 »
THIS ^^^^also ,run your hand around the tread feeling for high and low spots,normally caused by worn shockers.
Offline sam_xr2i
« Reply #7 on: 07 February 2012, 21:17 »
ye changed the wheels over at the same time as doing the bearings, makes noise with either set on
Retro_look
« Reply #8 on: 07 February 2012, 21:29 »
dont want to sound patronising but did you replace the ring/shell aswell as the bearing? (everything in the kit)
there could be a slim chance that both sets of tyres are castellated? especially if they have been used on the vehicle before? have you actually checked the tread yourself?
Offline tweed
« Reply #9 on: 07 February 2012, 21:52 »
I thought that too Retro.
I normally do rear disc at the same time because bearings shells are hard to get out and in.
I had to press mine in. Maybe yours ain't fully pressed in. In at a slight angle maybe.
