Author Topic: n00b exhaust question  (Read 1069 times)
Offline dagzie
« on: 03 February 2012, 23:56 »
basically I'm new to the vw scene and I've stared off with a 1.4 mk3 because basically its cheap everything, my question is whats the bore on the exhaust? and will a gti system or even backbox fit on? I'm asking this as I'm looking for an aftermarket exhaust but cant see to find any reasonable ones for a 1.4 cheers
Offline dagzie
Re: n00b exhaust question
« Reply #1 on: 07 February 2012, 19:34 »
bump
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 07 February 2012, 20:46 »
easier with a full system as you just need a step/sleeve at the back of the cat......
backbox will cause more issues as it curves near the back axle and any sleeve here makes it point/hang oddly
Retro_look
« Reply #3 on: 07 February 2012, 21:16 »
if you have a powerflow place near you, they are quite reasonable to get one fitted from scratch.
Offline Khare
  • The bear that khares
« Reply #4 on: 07 February 2012, 21:28 »
Just FYI, if you plan on changing the exhaust for performance gains then forget it, there is none from a 1.4. If you want to get an exhaust for looks/sound you're better off buying a catback exhaust as boneybradley said, but get a second hand one as it'll be around the £70 or so mark, rather than £200+ from an exhaust specialist to fabricate one for you/sell you one.
Offline dagzie
« Reply #5 on: 10 February 2012, 12:24 »
just looking for looks and a bit of noise atm only driving a 1.4 due to being low on funds and with it being my first golf I though i would get a cheap one and obvs because I love the way it looks and drives my next car will more than likely be a gti :)
Offline Dan_GTi8v
« Reply #6 on: 10 February 2012, 14:17 »
get a gti cat back fit a sleeve then stick it on the gti when you upgrade :)
