Author Topic: GTD Engine Idling Speed  (Read 8266 times)
Offline linc-dub
« on: 02 February 2012, 21:10 »
Has anyone had any problems with their GTD not idling at the usual 780 rpm (excluding the regeneration cycle)?
My GTD will start up at 780 rpm then run at 980 rpm until the temperature gauge reaches 90 degrees or sometimes will still idle at 980 rpm 15-20 miles into a journey.
The car has been back to the dealers twice and they say the diagnostics says nothing is wrong, the engine is desinged to rev at 980 rpm when there is load on it e.g. heater and lights
What's anyone's views on this - as I'm unhappy with this scenario and having previously owned a 59 plate GTD for 2 years which never did this and my current 61 plater has only done this for 4 weeks
Picked up 02.09.17 Mk7.5 GTD Isaac Blue, Manual 5 Drs, DCC, Reversing Camera, Keyless, 90% tints, Heated front screen, Mudflaps all round
Sep 2015 65 plate Mk7 GTD Carbon Grey, Manual, 5 Drs, DCC, Reversing Camera, Sat Nav, Keyless, Sport & Sound, Mudflaps all round
2013 63 plate Mk7 GTD, Manual, 5 doors, Carbon Grey Metalic, ACC, Reversing Camera, Mudflaps front & rear - Took delivery October 2013
Offline Buck
  • Das Auto
Re: GTD Engine Idling Speed
« Reply #1 on: 02 February 2012, 21:21 »
Mine tends to idle at around 800 but rarely seen it idling at 1000
Recently I have noticed mine being a bit 'lumpy' at idle when cold but even then I don't think it is increasing the RPM
Offline ajmoir36
« Reply #2 on: 02 February 2012, 21:57 »
Mine definetly idles faster when its really cold first thing after starting not 980 though more 900. It does normally idle at 780ish. I wold have said that's its doing alot of regens by the sound of it.  Are you doing lots of short journies? Mine can do regens at anytime and will always start doing it again the next time at some later point if it doesn't get to complete properly on the last cycle.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline linc-dub
« Reply #3 on: 02 February 2012, 22:07 »
hi ajmoir36
my journeys are mostly 15 miles to work and then 15 back daily, plus 60-100 mile runs each way every fortnight, with not much town driving.  Also I'm rather a fast driver, so I don't think my GTD is 'blocked up'.
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #4 on: 02 February 2012, 22:12 »
Mine does this when it's very cold too  :wink:
Offline ajmoir36
« Reply #5 on: 02 February 2012, 22:41 »
hi ajmoir36
Is it more often than every 800 miles is. As that's how often mine does it. I do 28 miles each way per day. Maybe the fastvdriver which is what causes it as it produces more soot?
Offline SRGTD
« Reply #6 on: 02 February 2012, 22:51 »
^+1. Idles at around 900-950 rpm when the weather's cold and the engine's not up to normal operating temp at this time of year. Normal idle speed in warmer weather or when the engine's fully warmed up at this time of year is just under 800 rpm. I try and make sure I give it at least one good run each week to hopefully avoid DPF problems in future as currently, journeys to and from work are around 7 miles each way.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Keithuk
« Reply #7 on: 03 February 2012, 01:10 »
Mine idles a touch over 800rpm cold and 800rpm hot.
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline GolfTi
  • ..gotta feel for my automobile..
« Reply #8 on: 03 February 2012, 19:16 »
Is this something to do with the diesel 'waxing' a little?
Winter diesel is different to summer diesel to prevent freezing and waxing. It still gets a little thicker in very cold temperatures though.
Mk7 GTI. DBP, DCC, Winter pack. Mine since new, July 2013.
GTI no. 4. Golf no. 5.  VW no. 7.
