Author Topic: What do i do with this sensor thing that was on my airbox? HELP!  (Read 2455 times)
Offline Jayz
What do i do with this sensor thing that was on my airbox now i have a cold air intake? btw i have a 1.8t agu.
Offline Dave_IOW
Zip tie to your metal pipe.
Needs to stay cool.
Its called an ignition amplifier.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
Needs to stay cool.
+1 not a problem.
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline gavgtiturbo
I screwed mine to the threaded hole in the picture on the bulkhead  :wink:
Offline Jayz
Cheers guys! so do i just cable tie it as it is to the pipe? or unscrew the metal plate from the ignition amplifier and put the ignition amplifier on one side of the pipe and the metal plate on the opposite side and cable tie them together with the pipe in between?
Offline Jayz
Is that in the 1st pic mate?
Offline mcgee9t2
it just needs to be kept cool and kept somewere its not going to jiggle around and snap off, so dont mount it on the engine and dont leave it hanging, up to you what you do with it tbh, ide just screw it onto one of the threaded holes were the air box was like said previously
Offline Jayz
ok mate gotcha cheers.
Offline cullygti
and dont take the metal bit off leave it as a whole and fix it out the way all still connected if that makes sense  :grin:
Offline Jayz
all sorted thanks peeps!  :smiley:
