Author Topic: list of reasons 1z timing could slip  (Read 1992 times)
Offline dubpirate
« on: 01 February 2012, 18:36 »
any ideas as mine has done
thanks dan
Offline tweed
Re: list of reasons 1z timing could slip
« Reply #1 on: 01 February 2012, 18:39 »
old belt and tensioner giving enough slack to jump
Offline dubpirate
« Reply #2 on: 01 February 2012, 19:00 »
wicked pal so if i get a genuine vag kit belt and tensioner
should be fine
Offline tweed
« Reply #3 on: 01 February 2012, 19:12 »
I would check history to see when it was last changed. If you cant find anything then get a cam belt kit  :wink:
Offline dubpirate
« Reply #4 on: 01 February 2012, 19:35 »
was done just before i got it
ran ok then gradually got worse then wouldnt start
took it to a diesel specialist
he saw a wobble on bottom pulley so he did than new from vag
and relined the timing said it was 2 teeth out
so i got it back started streight up and did so for about 4-5 days
the started to turn over alot before starting again and now we are back to the start
it seems to be back to stage one
now when i have been booting it a bit anything over 2500k revs it rattled loudly from the engine bay
im guessing the timing has slipped
as it will start but has to turn over for about 30-seconds to a minute (loads a smoke)
so i have bought a genuine vag cambelt kit with tensioner
i believe that rattle was the tensioner as that also had a wobble on it
any thoughts guys
« Reply #5 on: 01 February 2012, 20:54 »
Could be a worn crank if the pulley has been allowed to run a long time whilst loose.
Offline dubpirate
« Reply #6 on: 04 February 2012, 21:04 »
the mechanic replaced the old bottom pulley
showed me it it had slight wear
only slight tho
he replaced it with a new one
he is a diesel specialist
so im sure he would of noticed if the crank was worn
« Reply #7 on: 04 February 2012, 21:06 »
only slight tho
Well I would get it rechecked, you may find the key slot has worn.
Offline dubpirate
« Reply #8 on: 04 February 2012, 21:08 »
does this mean new engine :-(
« Reply #9 on: 04 February 2012, 21:09 »
Yes or a rebuild with a new crank.
