Author Topic: axle stands  (Read 2348 times)
Offline mrsaunders
axle stands
« on: 01 February 2012, 13:05 »
Where's the best place to wack my axle stands, the manual says on the sills but there's no way I'd trust mine, is each end of the subframe ok? And just got a bottle jack for £15 is that an alright deal and do many people use them (some pikey stole my trolley a few months back so thought I'd replace it with the bottle  :angry:
Offline Martz
Re: axle stands
« Reply #1 on: 01 February 2012, 13:16 »
Have a good look under the car and you will find a good solid area. Good luck with the bottle jack though, becareful.
Martyn
Offline clancy
Re: axle stands
« Reply #2 on: 01 February 2012, 13:26 »
halfords 2 tonne trolley jack is only £30 bud, perfetly fine for lifting onto stands etc
MK3 GTI 16v
Offline tweed
Re: axle stands
« Reply #3 on: 01 February 2012, 15:01 »
I put mine on my rear beam and subframe. Best places for them.
If you want to work on rear beam or subframe, then get some soft wood and place that between axle stand and somewhere flat
Offline geeksteve
Re: axle stands
« Reply #4 on: 01 February 2012, 15:17 »
Same. I pick something flat, as close to something structural as I can. That way there's a fair chance it wont appear in the foot wells :P
Offline sychosis
Re: axle stands
« Reply #5 on: 01 February 2012, 15:41 »
I usually put them under the subframe just on a little flat piece in line with the jacking point, or the rear beam.
« Last Edit: 01 February 2012, 15:46 by sychosis »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: axle stands
« Reply #6 on: 02 February 2012, 00:18 »
Subframe rear mounting bolts are certainly solid enough for it to sit onto axle stands.
