Author Topic: New clutch necessary?  (Read 1730 times)
Offline Leroy
  • Golf GTI Anniversary 16v
« on: 31 January 2012, 18:29 »
My 8v Anni has been crunching 2nd gear ever since i had the gearbox oil changed recently, which i was told would solve the problem not make it worse, so ive sourced a recon gearbox locally but my mechanic says i should change the clutch at the same time.
Theres nothing up with the clutch so to save myself £60 i told him to put the old one back in and i'll chance it.
I just wanted to ask you guys in your infinite wisdom, Have i done the right thing?
Offline Luke1981
Re: New clutch necessary?
« Reply #1 on: 31 January 2012, 18:34 »
I personally would have put a new clutch in whilst the gearbox is out. How many miles has the car done with your clutch?
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline Leroy
« Reply #2 on: 31 January 2012, 18:36 »
10k since i have it, but don't know before...
Offline AudiA8Quattro
« Reply #3 on: 31 January 2012, 18:40 »
+1 I would do this for sure if i didn't know when it was last replaced...
Offline Luke1981
« Reply #4 on: 31 January 2012, 18:42 »
If your happy it is in good working order then just risk it and see how you go. It's not the biggest of jobs if it goes wrong in the future. If you don't have the skill to do it yourself it will cost around £250 - £350 to get a garage to sort it :smiley:
Offline Leroy
« Reply #5 on: 31 January 2012, 18:45 »
Ive got piles of history so i'll see if i can find a receipt for the last clutch, roughly what mileage would you expect to change it then? bearing in mind i never thrash it?
£250-350 is that really how much it costs for a new clutch and fitting?
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #6 on: 31 January 2012, 18:51 »
Well the mechanic will be able to visually inspect the clutch given that the gearbox is out so best bet is to make an assessment then. If there is plenty life in in no point wasting the money. A clutches life span can vary widely depending on how the cars been driven. I've seen some go at 30,000 miles and seen others do much much more. My Leon Cupra has done over 100,000 miles on the same clutch.
« Reply #7 on: 31 January 2012, 18:56 »
Up to you, but i would get it done for the piece of mind.
Offline Leroy
« Reply #8 on: 31 January 2012, 19:55 »
Top advice guys, much appreciated. I'll get him to check it as Jamo says.
Offline boneybradley
  • Back in a Mk3...
« Reply #9 on: 31 January 2012, 19:58 »
thing is to replace it's taking the box off again, I would spend the extra and fit new.
