Author Topic: Induction kit?  (Read 1222 times)
Offline myles841
Induction kit?
« on: 30 January 2012, 12:56 »
Hi all,
Just after some information on induction kits for my mk4 gti 2L 8v, is it worth using an induction kit? or is it just as good to use a panel filter?
Offline mcgee9t2
Re: Induction kit?
« Reply #1 on: 30 January 2012, 13:08 »
you wownt see any real performance gains from either, personally ide just use standard or a pannel filter because its cheeper than buying an induction kit, pipework, sheild from hot air/water splashing up from road ect pluss takes 2 mins to put panel filter in there rather than a hour or so for induction kit.
Re: Induction kit?
« Reply #2 on: 30 January 2012, 13:28 »
Stick with a panel filter.
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Re: Induction kit?
« Reply #3 on: 30 January 2012, 16:57 »
If you had a turbo id say go for induction kit for noise, but as you have a 2.slow then stick with panel  :grin:
Offline Sketcha009
Re: Induction kit?
« Reply #4 on: 30 January 2012, 22:38 »
like they said. you will not notice and power difference. maybe get a little whoosh noise but its alot of money to spend just for the sound. pannel is your best bet!
2002 Gti 1.8 Turbo
Offline james2
  • No scammers please.
Re: Induction kit?
« Reply #5 on: 30 January 2012, 23:29 »
induction kit anyday.  :wink: sounds better and looks good.  :evil:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Dalo Harkin
Re: Induction kit?
« Reply #6 on: 01 February 2012, 13:16 »
Agreed - but the bits from ebay and you are looking less than a panel filter.
I got a piece of ali tube about 10" long with a slight bend (about £10)
A filter (about £10)
a silicone joiner (about £3)
