Author Topic: Roof Antenna  (Read 2098 times)
Offline GTI:Gibbo
Roof Antenna
« on: 29 January 2012, 19:42 »
I'v just purchased a shark fin antenna and will be fitting it once arrived. My question is what is the best way to remove the Mk4 OEM base unit off the antenna?
Offline daz veedub
  • Operation 1.8t bolf
Re: Roof Antenna
« Reply #1 on: 29 January 2012, 19:47 »
undo a nut under the headlining mate
Offline GTI:Gibbo
Re: Roof Antenna
« Reply #2 on: 29 January 2012, 19:52 »
Cheers daz will it just pull off then mate?
Offline daz veedub
Re: Roof Antenna
« Reply #3 on: 29 January 2012, 19:55 »
yeah  pull headlining down abit from the rear end and undo a nut then will pull out  :smiley:
Offline damien010685
Re: Roof Antenna
« Reply #4 on: 29 January 2012, 20:16 »
Pics once ure done want to see how this looks pal
Offline GTI:Gibbo
Re: Roof Antenna
« Reply #5 on: 29 January 2012, 21:33 »
Okat thanks.. Yeah will get some before and after shots mate
Re: Roof Antenna
« Reply #6 on: 29 January 2012, 21:43 »
I am 99% sure you will need an aerial adaptor as the standard aerial lead is different to aftermarket.
Offline GTI:Gibbo
Re: Roof Antenna
« Reply #7 on: 29 January 2012, 22:07 »
Hmmm well this one says in the listing it's just a case of plug n play.. It wasen't cheap!  :rolleyes:
Re: Roof Antenna
« Reply #8 on: 29 January 2012, 23:58 »
Have you a link for said aerial :smiley:
Offline GTI:Gibbo
