Author Topic: Help Please!  (Read 1385 times)
Offline Alan16ac
Help Please!
« on: 29 January 2012, 13:29 »
Two things, first off my 1.8t AGU has a Atmospheric Dump Valve on, so I've picked up a standard valve of a breaking 1.8t to replace it with until I can afford a forge one.
However I can't see how the hell to replace it?
The Dump valve only has 2 pipes off it, a big one and then a small one, really small looks like a wire.
But the recirc valve has two bigger outlets perpendicular to each other and then a little outlet on the top.
I probably sound really thick now lol, but I'm stumped!
Second, my car keeps dropping boost from 11 to about 6 after 4000 rpm and judders a bit.
I've got a MAF code coming up so I unplugged the MAF sensor and it ran fine with no juddering, but it was only boosting to 3psi but held this up to the red line and ran really smooth.
Advice please! Lol.
Offline tokemk4gti.t
  • 2001 gti turbo :-)
Re: Help Please!
« Reply #1 on: 29 January 2012, 13:43 »
u cant run an atmospheric.. probly losing boost through that id hazard a guess at other than that a boost leak check your hoses/lines/jubillee clips and get a new maff :undecided: il see if i can get a quick snap of how my dv is for ya on the way back out to work in a min.
Offline Alan16ac
Re: Help Please!
« Reply #2 on: 29 January 2012, 14:28 »
Thanks, but I've just managed to fit it, turns out the hole had been blocked off but I've found how to do it after staring at the engine bay for an hour.
It's now making a fluttering sound instead of the blow off noise it was before, is that right?
It's still losing boost at 4000ish rpm though  :undecided:
Offline topher
  • Administrator
  • fully functioning
Re: Help Please!
« Reply #3 on: 29 January 2012, 14:30 »
either the DV is knackered or the little vac hose to the top of it has a split in it.
Re: Help Please!
« Reply #4 on: 29 January 2012, 15:45 »
id say vac hose mine splits once a month lol.. i no wen its gone tho cuz it sounds like a suburu and is flat as a trod in cowpat big difference in the pull of the car!!
Offline Alan16ac
Re: Help Please!
« Reply #5 on: 29 January 2012, 15:56 »
Which is the vacuum hose?
Offline topher
  • Administrator
  • fully functioning
Re: Help Please!
« Reply #6 on: 29 January 2012, 15:58 »
technically they're both vac/boost hoses, but the one you're interested in is the little thin one that goes to the top of the DV
Offline richw911
Re: Help Please!
« Reply #7 on: 29 January 2012, 16:09 »
You will find it has gone brittle.
Offline Alan16ac
Re: Help Please!
« Reply #8 on: 29 January 2012, 16:18 »
The hose you're talking about on mine ends up at a T splitter thing, and goes off in two directions.  :undecided:
Re: Help Please!
« Reply #9 on: 29 January 2012, 16:59 »
you got a boost gauge/vac gauge?? boost gauge shouldnt be from there anyway but u did have an atmospheric blow off so if u have theyve took from the wrong place  : :shocked:
