Author Topic: gauges.  (Read 5906 times)
Offline cullygti
« Last Edit: 29 January 2012, 12:18 by cullygti »
Offline tokemk4gti.t
  • 2001 gti turbo :-)
Re: gauges.
« Reply #21 on: 29 January 2012, 13:22 »
thats ore or less the same pod im lookin at mate but its a trebble pod in carbon black effect on demon tweeks..was just thinkin to get that and see if i can do somethin with fabricating it to match the pillar might look a bit iffy throwin a black carbon pod on a cream pillar :-/
Offline big stevie
  • "what doesnt kill me makes me stronger"
Re: gauges.
« Reply #22 on: 29 January 2012, 19:34 »
glad this has cropped up i will be fitting my boost and volt gauge this week as feeling a lot better now, ive found the link for fitting boost gauge on here which is good, but im looking for a very simple place to tap into for 12v from the ignition as my gauges are both smoked and light up when car is running, so i need a simple place to pick up 12v if anyone can help if not i was just going to run a wire from radio as that must be the easy route i can fit radios and amps and do little jobs but im no auto electrition any help guys would be appreciated and pics of where would be even better heres what im fitting gauge holder is very nice and perfect fit but £32 for a bit of plastic so it should, its cost me over £100 for all the stuff to fit but should look the dogs when installed, heres my pod and gauges. :smiley: :smiley: :smiley:
where did you get the double gauge pod from big-stevie
i got it from ebay here you go made for golf fits pillar trim perfect no problems, probably could buy a universal one and play with it but i dont have time anymore and was impressed with the fit and is very strong.  :smiley: :smiley: :smiley:
http://www.ebay.co.uk/itm/200690223247?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
black 5 door 18t aum engine with 19" lm reps and homemade induction, awesome forge 007p,pressed plates, pillar mounted boost and voltage gauge.
Offline cullygti
Re: gauges.
« Reply #23 on: 29 January 2012, 21:26 »
thats what i did got a universal pod and covered it in some headliner material from another gti
Offline Darksider1.8T
Re: gauges.
« Reply #24 on: 29 January 2012, 22:51 »
cheers big-stevie just brought one of them and i brought a double gauge pod for the steering wheel cowling
*boost gauge
*oil pressure
*oil temp
*volt meter
Re: gauges.
« Reply #25 on: 29 January 2012, 23:22 »
yer cully i reckon that looks miles better than a bit of black plastic lol gettin hold of the headliner material might be a ball ache tho
Offline cullygti
Re: gauges.
« Reply #26 on: 29 January 2012, 23:33 »
yes it is mate but one of the lads was breaking his on here as he had a anni liner so asked him to send me some surplus material for a small fee  :wink: was a while ago now or pop to your local scrappy etc you get the idea mate
Offline big stevie
Re: gauges.
« Reply #27 on: 30 January 2012, 06:56 »
whatever floats your boat i suppose the black plastic goes with the dash and makes it quite stand out which i like and should still look quite o.e.m just spent around £115 and want it to look nice,  and the fit is very good hence why i didnt buy a universal one and have gaps i did think about it as you can get universal ones for very very cheap money   ( £8 ) but are very soft feeble plastic this one is very strong indeed i put gauges in it to try and fitted nice and tight without using fixings but was £32 as thay say you get what you pay for i suppose, will look very nice once fitted going to start this week.  :smiley: :smiley: :smiley:
oh anyone got any ideas for 12v supply for the volt meter and boost gauge that i can use need an easy one to use as im no auto electrition.
Re: gauges.
« Reply #28 on: 30 January 2012, 10:49 »
get some pics up stevie wen u start  :laugh: all ive found mate is that most take the display illumination feed from the instrument/clocks dimmer switch so that when u dim the lights the gauges also follow suit plus its right where the gauges are goin aswell but to be honest you can splice into the switch live of the stereo or any other switch live but then they would be illuminated all the time then and not sure how long the back light on those babies will last :-/
Re: gauges.
« Reply #29 on: 30 January 2012, 10:57 »
I don't have a volt meter but you can take a feed from the fuse box all ok, lighting wise I spliced mine into the light switch, just get a test lamp and find the one that becomes live when you switch the lights on, the dimmer feed is a very small wire so was not sure with adding extra load so did not use it.
Earth wise mine had a common earth point by the steering column so I used that.
« Last Edit: 30 January 2012, 11:05 by Wayne »
