Author Topic: Forge actuator...  (Read 1395 times)
Offline Chris#101
Forge actuator...
« on: 27 January 2012, 22:17 »
So I've has my forge actuator sitting here new in its box for months now and thought id best far round to fitting it  :grin:
So has anyone got a how to guide or any tips? Is it possible to fit without removing turbo?
All tips and hints welcome
Cheers :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Forge actuator...
« Reply #1 on: 27 January 2012, 22:32 »
I got away with just dropping the turbo slightly and not removing it completely
basically all pipes out the way, undo the turbo support bracket bolt (holds the turbo to the block via a bracket), undo 3 bolts on the top of the manifold and turbo should drop slightly
undo 13 manifold nuts, remove manifold.
Undo oil banjo to gain access to 1 of the small bolts securing the actuator bracket, other 2 are easy to get to
Reverse  :wink:
Oh and enjoy trying to find the "hidden" manifold nut, you can only access this by pushing the turbo down slightly and going in blind  :laugh:
Offline Chris#101
« Reply #2 on: 27 January 2012, 22:48 »
Cheers for the quick response   :cool:
Lovely little guide there
Is.removing the manifold necessary?:)
Its there anything I should replace whilst in that area?
Offline Darksider1.8T
« Reply #3 on: 27 January 2012, 22:51 »
im in the same boat mate got mine here sitting next to me with one green spring, one yellow spring and 2 different brackets just in case it dont fit with the original one, ive not got the patience to do mine.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 27 January 2012, 22:54 »
yes mate manifold needs to come off to gain access to the bolts holding the bracket on
Just one thing, make sure you push the downpipe and turbo back up when you put the 3 long bolts in to join the turbo back to the manifold, if you don't you'll cross thread the bolts (talking from experience)
Offline Toby
  • Car - less
« Reply #5 on: 27 January 2012, 23:07 »
My forge acuator is really stiff need a rebild kit me thinks
Currently down under
Offline Chris#101
« Reply #6 on: 27 January 2012, 23:11 »
Okey cheers bud appreciate the advise :wink:
What sort of hours would you put on the job providing everything goes to plan? :grin:
Offline topher
  • Administrator
  • fully functioning
« Reply #7 on: 27 January 2012, 23:45 »
i reckon give yourself a whole day if you've never done anything like it before. After you've done it once, its a 2 hour job tops.
