Author Topic: Vibration above 60mhp  (Read 1662 times)
Offline nukezz
« on: 27 January 2012, 16:19 »
i was driving home from work today and once i reached 60its fine but if i accelerate anymore i get a vibration from my front passenger side wheel.
when i say vibration i mean as if the wheel isnt balanced but it is.
Offline richw911
Re: Vibration above 60mhp
« Reply #1 on: 27 January 2012, 16:54 »
Lost the weights so now its out of balance? Wheel nuts all tight?
Offline Darksider1.8T
« Reply #2 on: 27 January 2012, 17:13 »
or buckled wheel
Offline gavgtiturbo
« Reply #3 on: 27 January 2012, 17:40 »
check both walls of the tyre passanger front was getting vibration from 50mph upwards i had an egg on the inside tyre wall.
Offline nukezz
« Reply #4 on: 27 January 2012, 17:48 »
I was thinking It could be a buckled wheel sticking brake or bottom ball joint or anything suspension wise. My plans tonight = destroyed the ill have to get it up on my ramp and have a closer inspection. The car comes first  :smiley:
Offline vwfiend
« Reply #5 on: 27 January 2012, 18:10 »
I had a wheel bearing gone once on a non vag car that did the same thing........... Worth a look
Offline golf-sib
  • Турботазик
« Reply #6 on: 27 January 2012, 20:33 »
Wheel bearing tend to squeek till they collapse and then you know about it, I remember mine collapsing on the a2 5min from home in the polo  :grin:
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline nukezz
« Reply #7 on: 27 January 2012, 20:41 »
Just back from my garage. i jacked up the car and spun the wheel and the noise coming from the gearbox/drive shaft area sounds like broken metal..?  :undecided: but it drove 5 miles there and 5 miles back and runs ok apart from vibration from the passenger side.
Offline richw911
« Reply #8 on: 27 January 2012, 20:43 »
Cv joint?
« Reply #9 on: 27 January 2012, 20:45 »
wheel hub nut not on tight?
