Author Topic: Vibration above 60mhp  (Read 1653 times)
Offline RhosneigrGaz
  • More Doors Crew!
Re: Vibration above 60mhp
« Reply #10 on: 27 January 2012, 21:16 »
Get underneath and grab the drive shafts one at a time and wiggle them to check for play.
I had a similar wobble on my last gti and one shaft had a good 1cm of play in it!!!
'02 3dr Tornado Red Gti 20v Turbo
Offline nukezz
« Reply #11 on: 27 January 2012, 22:14 »
Just back from my garage. i jacked up the car and spun the wheel and the noise coming from the gearbox/drive shaft area sounds like broken metal..?  :undecided: but it drove 5 miles there and 5 miles back and runs ok apart from vibration from the passenger side.
Cv joint?
well thats what my dad said, i need to get a cv boot as the other is split. im goin to get him to check it out he knows alot more than me.
Offline james2
  • No scammers please.
« Reply #12 on: 27 January 2012, 23:15 »
Cv joint?
+1
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Sketcha009
« Reply #13 on: 30 January 2012, 22:40 »
3 possible causes.
Buckled wheel
Cv joint
Wheel bearing.
sorry just read the post and people had mentioned Cv. jack her up and check the wheel
« Last Edit: 30 January 2012, 22:56 by Sketcha009 »
2002 Gti 1.8 Turbo
