Author Topic: MOT Failure advice  (Read 5796 times)
Offline walchy01
MOT Failure advice
« on: 26 January 2012, 19:14 »
Evening All
Please can someone advise me if the MK2 has 2 rear fog lights, i was under the impression that they only have 1 :undecided: :undecided:
It's just that it failed on this :cry:
Thanks
Walchy
Offline pigbladder
Re: MOT Failure advice
« Reply #1 on: 26 January 2012, 19:20 »
yeah they only have one as standard , theres provision for the other side for the european market , can join em up if you wish
Offline walchy01
« Reply #2 on: 26 January 2012, 19:21 »
Thought i was going mad, which is why i thought i'd ask the question, well thats one less failure then off the sheet, thought the tester would have known this :laugh: :laugh:
Thanks
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 26 January 2012, 19:25 »
Thanks
Sounds like you got a real nit picker....
Lots of cars only have one - so you don't blind other drivers...
What a Pillock
For More Info Click To See;
Offline h8v
« Reply #4 on: 26 January 2012, 19:26 »
They only have one as standard. (offside)
I made mine two though, by adding a bulb to the nearside bulb-holder and a cable connecting the left and right hand light fittings.
You need a bit of investigation to locate the correct connector on each bulb-holder!
h8v
Offline walchy01
« Reply #5 on: 26 January 2012, 19:28 »
Glad that people are saying what i thought, honestly thought i was losing it :embarassed:
I will advise him when i take it back, not used to these classic cars these MOT boys :smug:
Thanks
Offline pigbladder
« Reply #6 on: 26 January 2012, 19:35 »
if the car hasnt been messed with there should be a blank over where the other bulb goes ..just punches out if you want to run 2
Offline walchy01
« Reply #7 on: 26 January 2012, 19:37 »
will have a look and see...Thanks :wink:
Offline dubber36
« Reply #8 on: 26 January 2012, 19:42 »
Even if a car should have 2, so long as the off side one works, it passes.
Offline walchy01
« Reply #9 on: 26 January 2012, 19:50 »
Shocked they dont actually know that when they test cars all day :angry:
